Author Topic: Tyre Pressure Light  (Read 2211 times)
Offline edition_30
Tyre Pressure Light
« on: November 27, 2009, 09:39:07 am »
Last week my tyre pressure light was lit on my dash.. i checked my tyres & pumped up as they were down.
I reset the light by using the switch & has been fine for a few days until this morning when the light has come back on. I'm slightly worried as the manual mentions that it could indicate a system fault as well as tyre pressure.. im going to check @ lunchtime the pressures again but i recently got stage 1 revo & just wondering if it could have caused an issue
Offline NB07
Re: Tyre Pressure Light
« Reply #1 on: November 27, 2009, 10:22:03 am »
nothing to do with the map fella, maybe got a slow puncture  :sad1:
Offline edition_30
« Reply #2 on: November 27, 2009, 11:04:47 am »
this is what im hoping mate.. gunna check the pressures again today to see if one has dropped significantly.. will report back
« Reply #3 on: November 27, 2009, 12:53:10 pm »
You need one of these beauties......
It constantly monitors the pressures and temperatures of the tyres, gives out an audible warning when a tyre gets too low with the pressure and means you have a consistent way of checking the tyres day on day for leaks etc :happy2:
It also means you can ignore the car's OEM system, which is a little "agricultural" technology-wise :smiley:
« Reply #4 on: November 27, 2009, 01:30:26 pm »
Like where youv'e mounted that John!  :congrats:
« Reply #5 on: November 27, 2009, 01:37:31 pm »
 :signLOL:
Space was made to measure, so it was a no brainer. :happy2:
« Reply #6 on: November 27, 2009, 06:13:46 pm »
This happened to me. A week ago typre pressure light came on. Checked all tyres. Rear offside was low (27psi instead of 37psi) but not puncture or damage. Reinflated and drove on. A week later, the same warning light came on. Checked the pressures and same tyre had dropped the same amount again. But this time I found a nail in thr rear offside tyre. Just out of range of repair so getting a new set on the rear.
