Author Topic: Is it possible to modify an ESP switch as an On/Off Button?  (Read 8144 times)
Offline usmangti
« on: March 02, 2015, 04:06:06 pm »
As above, reason being fancy having the ability to switch off an amplifier for a subwoofer when I have the kids in the car. Currently modifying the switch blank but also thought if I could use the ESP flipped around on the right it would illuminate also. Trying to keep it all oem looking rather than just use a rocker switch. I know you can buy custom switches of a site but they are nearly 70Euros delivered.
Ideally I am looking for a wiring diagram for the button. Also considering the Winter mode button also.
Thanks in advance
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Is it possible to modify an ESP switch as an On/Off Button?
« Reply #1 on: March 02, 2015, 05:20:17 pm »
im looking to do something similar to switch on and off my dab unit as I don't want it constantly powered on as we only use it sometimes. so far I have only found a rocker switch but also want to keep it oem.
you got a link to the custom switches?
Offline usmangti
« Reply #2 on: March 02, 2015, 05:46:26 pm »
« Last Edit: March 02, 2015, 05:48:01 pm by usmangti »
Offline usmangti
« Reply #3 on: March 03, 2015, 02:17:38 pm »
I have found this on the web, can anyone explain to me what wires need to be connected to illuminate and use as a on/off switch:
I'm thinking W for Woofer!
Offline doylebros
« Reply #4 on: March 03, 2015, 05:34:33 pm »
Subject to how your equipment needs to be wired this set up will work for most typical situations as long it's its a low amp circuit or a relay will be required as there's no swich rating details provided!
Pin 6 earth for illumination off dash lights on - (brown wire)
Pin 3 feed from lighting circuit for dash lighting illumination - (grey)
Pin 5 fused feed for the circuit to be controlled
Pin 4 switched side of circuit to activate item to be turned on upon button activation.
Pin 1 earth for the light illumination for the switch side of the circuit - the button will illuminate when the item controlled by the push button is in the on position.
Note pin 6 and 1 can be joined together.
« Last Edit: March 03, 2015, 05:52:18 pm by doylebros »
Offline usmangti
« Reply #5 on: March 03, 2015, 06:35:32 pm »
@doylebros thats is excellent thank you. Its just for a amp remote wire so the switch should be more than capable.
Can I ask, did you get that info from the pic above or a vw wiring diagram?
« Last Edit: March 03, 2015, 08:55:30 pm by usmangti »
Offline doylebros
« Reply #6 on: March 03, 2015, 07:17:42 pm »
Off your drawing
Offline SI-R32
  • -Receive: 126
« Reply #7 on: March 03, 2015, 08:15:09 pm »
Just to add a bit to this,  all vw switches are not on-off,  there like a door bell just push on,  so you will need to add a latching relay so with each press of the switch will turn relay on,  then next press will turn off,  plus regardless of power to the relay as it has a magnet in it hence latching it remembers it's last told command
Offline usmangti
« Reply #8 on: March 03, 2015, 08:58:25 pm »
@SI-R32 Thanks for the info, do you mean it will forget the last position when the ignition is turned on/off or literally like a door bell where it will only work aslong as the button is depressed. Because if Its not the the latter I could probably live with that.
Offline doylebros
« Reply #9 on: March 03, 2015, 09:28:02 pm »
All as stated above is correct!
However,your drawing for the switch offered is not a momentary switch so if your buying as per the drawing all will be good to go.
If you're going to use a VW switch you'll have to fit the latching relay or your amp will only work when you've got the button pressed.
Offline usmangti
« Reply #10 on: March 03, 2015, 09:40:00 pm »
Aah ok that makes sense. The wiring diagram is supposedly for the vw switch. So this latching relay, I've had a quick look on eBay and seen for about £20ish, is that how much they are?
Offline doylebros
« Reply #11 on: March 03, 2015, 09:56:42 pm »
Maplins do a latching relay less than £5.00
http://www.maplin.co.uk/p/12v-dc-2a-dpdt-miniature-latching-relay-n38aw
This is worth watching to help you understand
https://m.youtube.com/watch?v=n7SuHDmuVUk
Offline SI-R32
  • -Receive: 126
« Reply #12 on: March 03, 2015, 11:57:07 pm »
Sadly the Maplin one, although a good find,  isn't really suitable for your application as it comes with 2 coils,  one for on one for off.
You could use one with a magnet in so once you've pressed your switch and released it the contacts will stay closed until you press it again,  I paid 20 quid for mine from Farnell,  just had a look about nothing obvious I could see.
Or just get a normal relay with 2 sets of contacts and follow the superb tutorial that John posted up
« Last Edit: March 04, 2015, 12:07:02 am by SI-R32 »
Offline usmangti
« Reply #13 on: March 04, 2015, 11:23:02 pm »
^^^yep that's what I'm thinking after watching that vid. I will be going to a breakers tomorrow and see if I can get the button. I will update this if I get it done.
Offline kingraza27
« Reply #14 on: January 22, 2016, 05:48:05 am »
Any update/progress on this? just thought about this idea myself, and wanted to know if you were successful?
at the moment, i have installed a on/off switch underneath the wheel to control the amp.
