Author Topic: How to change steering wheel safely?  (Read 3767 times)
Offline K9
  • VW LifeStyle
« on: March 12, 2015, 09:39:22 pm »
Hey guys and girls. Will be removing my gti steering wheel on a gti golf mk5 05. and want to hear from you who already have removed your once or twice, that how can i safely remove my wheel inc. airbag without setting it off or something like that  :ashamed: and can the indicator stalk be removed without disconnecting the steering wheel controller and install a oem cruise stalk?
Any tips how to code the new stalk via VCDS and reset the steering angle in VCDS?
Thanks you :)
Offline th3_f15t
  • -Receive: 183
Re: How to change steering wheel safely?
« Reply #1 on: March 12, 2015, 09:42:08 pm »
As for the wheel, battery disconnected is a must. Once the car is dead then there's no risk of airbag deployment, they require an electrical detonation to deploy so the age old myth that you can hit it with a hammer is rubbish.
Also, mark up the bolt you remove with a punch as you shouldn't re-use it more than 5 times.
Offline K9
  • VW LifeStyle
« Reply #2 on: March 12, 2015, 09:48:06 pm »
What if i don't have in handy a M12 tool to get the steering wheel bolt off? Can a Torx be used to?
And when everything is back together, should the key be removed and steering wheel centered and then connect the battery and turn ignition ON? and plug-in VCDS to clear codes and steering angle? <-- how is that done? will it be easier to reset angle sensor if the computer ( controller ) is no't disconnected at-all?
Offline doylebros
« Reply #3 on: March 12, 2015, 09:56:07 pm »
Kam88
« Reply #4 on: March 12, 2015, 10:03:08 pm »
By the looks of it you don't need coding only the tools provided
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: March 12, 2015, 10:12:42 pm »
I mentioned this in another post, you have you have to disconnect airbag, steering wheel,, steering wheel controller,  slip ring, angle sensor, and then stalk.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #6 on: March 12, 2015, 10:14:52 pm »
VW55raz has uploaded a pretty good video explaining what is needed to change the steering wheel. Unfortunately I can't locate the vid, so you may have to do a search.
Black Ed30
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: March 12, 2015, 10:22:36 pm »
Cheers Rob.
I already linked the videos in this topic
http://www.mk5golfgti.co.uk/forum/index.php/topic,94648
Offline savdog
« Reply #8 on: March 12, 2015, 10:38:04 pm »
take itto a garage .. much easier!!
Offline K9
  • VW LifeStyle
« Reply #9 on: March 13, 2015, 03:58:34 pm »
some say that you need to code with VCDS so it knows you have cruise stalk installed?
will cost a lot to make a garage do this ( like vw ) want to save :happy2:
do i have to unplug the controller? can't it be plugged in?
Offline savdog
« Reply #10 on: March 13, 2015, 07:34:28 pm »
Cost me £25 @ my local garage
Offline K9
  • VW LifeStyle
« Reply #11 on: March 13, 2015, 08:36:16 pm »
but if i do it myself then i learn and can do friends car etc  :happy2:
Offline K9
  • VW LifeStyle
« Reply #12 on: March 13, 2015, 08:49:38 pm »
@vw55raz can i loosen the controller without needing to unplug it?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #13 on: March 13, 2015, 10:10:12 pm »
you cant just loosen it. it has to come off. once it is off, the plugs can still stay on.
Offline Matthewsimone
  • -Receive: 39
« Reply #14 on: March 13, 2015, 11:03:29 pm »
I wouldn't even lift the lid on my toolbox for sake of £25 mate
