Author Topic: Projector headlights...  (Read 2284 times)
Offline Jarre
« on: March 22, 2015, 02:26:25 pm »
I've searched and I see that this topic is regularly discussed.
I currently have some projector headlights but they have no headlight motors. The beam is too high even at the lowest setting (even though my local MOT station said they'd pass) and so i'm looking to change them. When driving on the motorway it will light up all the signs on the side of the road etc, way way too high on the kick up.
Looks like my options are between the Depo ones and Hella ones, if I can get hold of them. So, my question is, what are the beam patterns like on each type of headlight? The more photos you have of yours the better. I just don't want to buy depos to find that they're no better than what i currently have!
Cheers!
Candy White ED30 :)
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
Re: Projector headlights...
« Reply #1 on: March 22, 2015, 07:08:13 pm »
Hella ones are impossible to get hold of at the moment, I tried. I have Depo ones and beam pattern is absolutely fine without adjustment for me, no one has flashed me and I can see perfectly :smiley:
Instagram @george_kersh
Offline Jarre
« Reply #2 on: March 23, 2015, 01:56:26 am »
So no excessively high beam that lights up all the signs and stuff?
If that's the case I'll probably just go for Depo ones as they're significantly cheaper than hella too!
Candy White ED30 :)
Offline Georrge
« Reply #3 on: March 23, 2015, 05:20:47 pm »
Nope not at all, I do however have my adjuster wheel set to the lowest setting, but for me it's perfect!
Offline Jarre
« Reply #4 on: March 28, 2015, 12:59:37 am »
Thanks :) do the depo's require the 6 o'clock mod?
Candy White ED30 :)
Offline boardyuk
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,88307.0.html
« Reply #5 on: March 28, 2015, 07:39:24 am »
Got Depo ones myself too and the pattern is fine. I had mine adjusted so they are at position 2 on the wheel so if I want I can pull the beam higher on empty roads.
Mine required the 6'oclock mod yes, although others have said they didn't need it so I guess it's just pot luck.
Offline Jarre
« Reply #6 on: March 28, 2015, 08:07:42 am »
Thank you!
Candy White ED30 :)
Offline Georrge
« Reply #7 on: March 28, 2015, 11:39:39 am »
Mine require the 6 o'clock mod too. Currently I haven't done it, and it isn't actually that bad, but I will be sorting it out next week as it doesn't take long to do :smiley:
Offline Jarre
« Reply #8 on: April 09, 2015, 01:53:36 am »
Received my depo headlights and will be buying a dremel tomorrow so I can do the 6 o'clock mod. :)
Candy White ED30 :)
Offline akbarirfan
  • -Given: 81
« Reply #9 on: April 09, 2015, 11:49:48 am »
Good stuff - weather is just right for fitting them too  :happy2:
Offline Jarre
« Reply #10 on: April 13, 2015, 08:44:42 pm »
Does anyone have photos of their beam pattern against a wall/garage for Depo headlights please?
Candy White ED30 :)
Offline Jarre
« Reply #11 on: April 15, 2015, 09:58:16 am »
No one got one?
Candy White ED30 :)
