Author Topic: 0-60mph  (Read 4306 times)
Offline jacobrownoly
0-60mph
« on: March 24, 2015, 12:39:33 am »
I clocked it at 5.6 - 5.7. (Its deffo under 6secs anyway)
Gti mk5 manual. Revo stage 1
« Last Edit: March 24, 2015, 01:37:22 pm by jacobrownoly »
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: 0-60mph
« Reply #1 on: March 24, 2015, 07:10:17 am »
 :indifferent:
Your 3.70 was much better
'07 Red manual
Offline Stu08
Re: 0-60mph
« Reply #2 on: March 24, 2015, 01:02:29 pm »
Impressive. My stage 2 (with S3 cooler and uprated charge pipes) does the 0-60 sprint between 6.0 - 6.4 seconds depending on weather conditions and road surface. You must get some launch.
How are you timing the 0-60?
Re: 0-60mph
« Reply #3 on: March 24, 2015, 01:25:14 pm »
Thanks mate, i just used a race stop watch.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: 0-60mph
« Reply #4 on: March 24, 2015, 01:56:52 pm »
 :happy2: Downhill :happy2:
Re: 0-60mph
« Reply #5 on: March 24, 2015, 03:02:31 pm »
Offline Phil_H
Re: 0-60mph
« Reply #6 on: March 24, 2015, 03:56:56 pm »
GPS or Speedo Reading? (Can't see the video)
Re: 0-60mph
« Reply #7 on: March 24, 2015, 04:20:52 pm »
Speedo reading
Offline Stu08
Re: 0-60mph
« Reply #8 on: March 24, 2015, 04:52:06 pm »
I used a Scangauge to time mine. You set the performance meter whilst stationary then accelerate off. The Scangauge starts timing the moment you move off and continues timing until you come back to a standstill at which point you stop it. Then you can review the speed increments showing the seconds it took to reach each increment.
If you're using a manual stopwatch and starting and stopping it yourself; you'll find the timings are way out regarding accuracy. Just something to think about.
Offline xjay1337
  • -Receive: 377
Re: 0-60mph
« Reply #9 on: March 24, 2015, 05:34:50 pm »
i timed the video at 6.29 on my stop watch.
for reference the speedo overreads by about 5-7mph.
Using a scangauge (or a polar mfd) reads the actual wheel speed sensor mph which is accurate and used by the odometer.
Offline th3_f15t
  • -Receive: 183
Re: 0-60mph
« Reply #10 on: March 24, 2015, 05:36:29 pm »
A lot of people will dismiss speedo based 0-62mph (0.100km/h) due to the inaccuracy and lack of precision. As mentioned, get yourself to a drag strip and get it done "officially", would be good to see how far off (or not...) your timings are.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: 0-60mph
« Reply #11 on: March 24, 2015, 08:47:24 pm »
^THIS
it's impossible to get an accurate time with a stopwatch anyway as human reactions aren't quick enough. . . Then you are using the speedo to judge when your at 60mph, again the speedo over reads.
When you consider the margin for error in both of those, you WILL be well out. . .
Offline Phil_H
Re: 0-60mph
« Reply #12 on: March 24, 2015, 09:13:26 pm »
Yep...
Speedo at 60, car not at 60.
You'd be over 6 Sec's if you got an accurate speed reading....
Standard DSG is 6.9, so you may just be able beat that with some decent gear changes and you current state of tune.
Offline Sug
Re: 0-60mph
« Reply #13 on: March 24, 2015, 09:47:44 pm »
It's not worth getting excited unless timed using a reliable accurate source
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
Offline topdawg
Re: 0-60mph
« Reply #14 on: March 25, 2015, 06:14:37 pm »
This poor dude gets hammered every time he posts!  :sad1: people are just jealous that there fwd cars aren't doing 0-60 in 3.7 seconds  :booty: :booty:
