A few updates...
My original mats were very worn and one was missing. So was on the look out for some cheap original mats on eBay. When I managed to bag some rare Edition 30 car mats for the GTI. For a princely sum of £26 + packaging (£34) ! Bargain, normally around £120 new!
They were in good condition, but needed a good clean up.
DSCN2365 by
Roger Freeman, on Flickr
Passenger side brushed off, ready for shampooing and a scrub.
DSCN2366 by
I had to change over the round connectors to the oval, off the original mats.
DSCN2367 by
All scrubbed and looking more presentable.
DSCN2369 by
Next up.....change the steering wheel trims. The usual peeled off finish, why did they think this would last?
DSCN2371 by
Anyway....easy fix. Pull off old ones...
DSCN2372 by
Push in the replacement....
DSCN2373 by
All done and looking much improved
DSCN2375 by
Interior updates done.......for now
DSCN2382 by
The next issue to sort out is my annoying coolant leak. Only filled this up a couple of days ago! After some research (on here
), I found it out to be another common issue with the TFSI engine.
DSCN2385 by
This is the area in question. Water leaking out and sitting on the gearbox housing. It is coming from a pipe connector union on the side of the cylinder head. An O-ring perishes and starts to leak.
DSCN2386 by
This is the part in question. Replacement from TPS. £16.
DSCN2388 by
This is the O-ring in question.
DSCN2389 by
Part number for anyone who needs it.
DSCN2390 by
Ok, so on with the fix....wish me luck!
DSCN2391 by
First off, I pulled the coolant temp sensor out and drained the coolant. Then after a massive amount of faffing to pry off most of the hose pipes, I decided just to loosen the connector and not remove it completely with some of the hoses still attached. And replace the O-ring only, good decision, me thinks!
DSCN2393 by
I took off the completely dryed out and crusty O-ring.
DSCN2394 by
This I took off the new part. You can't buy this separately. Pity..
DSCN2395 by
New O-ring in place.
DSCN2396 by
All back together. It's seems like it has cured the leak for now, we'll see if it does long term.
DSCN2397 by
That's it for now, more improvements to come soon......
Rog
