Author Topic: tyre pressures  (Read 10412 times)
Offline candy turbo
tyre pressures
« on: November 30, 2009, 09:50:25 pm »
how do you work out your tyre pressure ?  i have gone from 7.5 x 18 with 225/40/18 to 8x19 with 225/35/19 how do i calculate the correct tyre pressure ?????  any one  :happy2:
Offline bacillus
  • -Receive: 451
Re: tyre pressures
« Reply #1 on: November 30, 2009, 11:15:08 pm »
This is a smart ass reply but see if you can locate the recommended tyre pressure for the Golf R as iirc it comes with 19" rims. Apart from that you just have to experiment...
Re: tyre pressures
« Reply #2 on: November 30, 2009, 11:40:33 pm »
What does the tyre manufacturer advise?
Re: tyre pressures
« Reply #3 on: November 30, 2009, 11:47:50 pm »
i would try 34psi front and 32psi rear-take it for a drive and see how it goes
Offline gazbutS3
Re: tyre pressures
« Reply #4 on: December 01, 2009, 07:02:53 am »
I've played around with the pressures on mine. The book says something odd like 34.5 front and 30 rear for the std 225/40/18's can't remember exactly. I've tried this on the 19's and didn't get on with it, tried 34.5's all round, no good either. I now run 32.5 front and rear and I'm happy with it. I think sometimes the make of tyre can make a difference to finding pressures your happy with as the stiffness can vary from make to make :smiley:
Offline candy turbo
Re: tyre pressures
« Reply #5 on: December 01, 2009, 09:13:49 pm »
someone once told me that for every increase in size or tyre width how to work it out but cant remember , guy i had the wheels off says 32 psi so ill put them all to that and see how we go  :happy2:
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: tyre pressures
« Reply #6 on: December 02, 2009, 09:06:49 pm »
I've got 32psi all round... seems to be ok.
  • -Given: 380
  • -Receive: 442
Re: tyre pressures
« Reply #7 on: December 02, 2009, 09:32:03 pm »
I run 37 psi in 225/40/18 Goodyear Assymetrics on OZ 18x8 lightweight 8 Kg Alleggerita's. Happy in both wet and dry.
Re: tyre pressures
« Reply #8 on: December 02, 2009, 09:42:50 pm »
just keep a watch on the center tread of the tyres if you are running them at that pressure RR,as it will wear it down quicker
  • -Given: 380
  • -Receive: 442
Re: tyre pressures
« Reply #9 on: December 02, 2009, 11:15:27 pm »
....Will do. I check the tyres very regularly.
Re: tyre pressures
« Reply #10 on: December 02, 2009, 11:36:56 pm »
I run 33-34 all round. I found Goodyear eagle f1s very sensitive to lower pressures. Anything under 32 and it felt rubbish.
  • -Given: 380
  • -Receive: 442
Re: tyre pressures
« Reply #11 on: December 03, 2009, 12:11:32 am »
I know that having a TyreSure monitor is a completely unnecessary gadget but I have to say that I really enjoy having it and having the unadulterated luxury of constantly knowing exactly the tyre pressure (and temperature) in each wheel.
It has shown me how much pressures can fluctuate.
  • MUBster DUBster
Re: tyre pressures
« Reply #12 on: December 03, 2009, 12:17:20 am »
RR try inflating your tyres with nitrogen - I'd be interested to compare tyre temperature and pressure fluctuations.
I've been told that nitrogen doesn't expand unlike compressed air....
Re: tyre pressures
« Reply #13 on: December 03, 2009, 12:18:57 am »
It will be but it's not affected by the sort of operating temps found on a road tyre. To the point where it hardly changes
Offline Janner_Sy
  • -Receive: 113
Re: tyre pressures
« Reply #14 on: December 03, 2009, 08:39:28 am »
like the idea of knowing the temps, that would be especially good if you had toyo R888s which need a bit of heat in them if its not that warm out. what s the norm temp for tyres in normal driving and in hard driving then?
