Author Topic: tyre pressures  (Read 10411 times)
  • -Given: 380
  • -Receive: 442
Re: tyre pressures
« Reply #15 on: December 03, 2009, 10:16:55 am »
like the idea of knowing the temps, that would be especially good if you had toyo R888s which need a bit of heat in them if its not that warm out. what s the norm temp for tyres in normal driving and in hard driving then?
....Which is exactly why Hurdy got his TyreSure as he runs on R888's at times.
Yesterday my tyres started off at only 4ºC and rose to about 22ºC - It really depends on the day's weather and also because you don't tend to push your luck too much on public roads if the weather and conditions are restrictive.
I need to make some records of such info. Perhaps Hurdy already has some info - He's great at data.
Offline animal
  • .:R32
Re: tyre pressures
« Reply #16 on: December 03, 2009, 03:50:21 pm »
I run 33-34 all round. I found Goodyear eagle f1s very sensitive to lower pressures. Anything under 32 and it felt rubbish.
I'll second that! Makes a huge difference if they drop off a bit.
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: tyre pressures
« Reply #17 on: December 03, 2009, 05:02:51 pm »
What tyre pressure are you guys running/recommend for Michelin Pilot Sport 2s?
Offline edition_30
Re: tyre pressures
« Reply #18 on: December 03, 2009, 05:57:56 pm »
I'm currently running 45 all round.. seems fine to me
  • MUBster DUBster
Re: tyre pressures
« Reply #19 on: December 03, 2009, 06:13:43 pm »
Is this on the michies?
Offline bacillus
  • -Receive: 451
Re: tyre pressures
« Reply #20 on: December 03, 2009, 07:24:33 pm »
Seems a bit excessive...
Offline edition_30
Re: tyre pressures
« Reply #21 on: December 03, 2009, 09:45:02 pm »
Do you think? the ride feels okay.. little stiff but generally feels OK.. im currently on factory tyres, dunlop @ the front & contis & thee back.. any ideas on what sort of pressures i should be running?
  • MUBster DUBster
Re: tyre pressures
« Reply #22 on: December 03, 2009, 09:45:56 pm »
I thought it was 34psi all round
Offline Oli
  • -Given: 19
Re: tyre pressures
« Reply #23 on: December 03, 2009, 10:12:32 pm »
I think I ran 40 allround on my S3 with 19s. Have you asked over on Audisport.net, I'm sure that's where I got my answers last time - lot of S3 drivers over there.
Re: tyre pressures
« Reply #24 on: December 04, 2009, 01:42:52 am »
the tyre pressure's are inside the fuel flap
think yours will be 34psi front & 32 psi rear
Offline matsu
  • -Given: 78
Re: tyre pressures
« Reply #25 on: December 04, 2009, 08:49:56 am »
i now run 40 all round anything less is awful on these falkens and the lm reps.
there was a big thread not so long ago about using higher pressures which TT had a big input on i seem to remember! thats why i decided to go higher and also a bit of trial and error with these new rims.
ride feels better and i dont feel every bump and cornering is much better also.
lets see how the tread lasts but i,ll be changing brands soon as i ca anyway
