April 30, 2025, 10:29:04 pm
All Things Mk5
Performance Modifications
R-Tech Zone
(Moderator:
rtechniki
More praise for R-Tech
Topic: More praise for R-Tech (Read 2778 times)
Jknight89
Taking part
-Given: 2
-Receive: 1
April 25, 2015, 05:10:46 pm »
I visited R Tech today for my stage 1 remap. Only mods I've made to my golf are pre cat delete and a ITG panel filter. I had a courtesy call about an hour before my appointment just to make sure things were still going ahead and that i was on my way. When i arrived we had a quick chat and then they pulled the car in to begin the health check. After 10 minutes or so the guys came back to me and said the PCV was faulty and needed replacing prior to any tuning. I previously checked it as advised on here and thought it was ok but apparently not. I told them to crack on with replacing it as it needed to be done. Once the car went through its first run on the rolling road it came back at 210BHP which i was quite impressed with. Once the car had been mapped it then made 250.2BHP and 316FT/LB torque. We went out for a test drive and i have to say the car is so much more responsive. They even gave me 5 switchable maps incase i have any trouble with the clutch slipping in the future i can decrease the power. I am a very happy customer and would recommend R Tech to anybody thinking about having their car tuned. First class service. Keep up the good work guys
Shoy1980
Always Involved
-Given: 5
-Receive: 18
Re: More praise for R-Tech
Reply #1 on:
April 25, 2015, 07:19:45 pm »
Great stuff! Im looking to do the same. Couple of questions for you:
1) How much was the Stage 1 map?
2) How much was PCP and labour cost?
PM me if you like, thanks.
Vish8895
Always Involved
-Given: 29
-Receive: 6
Reply #2 on:
July 21, 2015, 12:25:23 pm »
How have they enabled you to switch maps?!
Vish
Dan_FR
Just look at my post count
-Given: 132
-Receive: 189
wait...what?
Reply #3 on:
July 21, 2015, 01:32:45 pm »
Added code to the ECU, switched using a combination of holding the brake and pressing the accelerator pedal to select the map, map selection indicated by the rev counter.
TFSI... Revo Stage 2+... . WMI.... VCDS HEX + CAN, MPPS, VAG Commander & VAG tacho - South Wales
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #4 on:
July 21, 2015, 02:50:55 pm »
Different ECU on a TDI. I think it's added to all his MED9/TFSi maps these days but don't quote me on that
GrayMK5GTI
Global Moderator
-Given: 125
-Receive: 248
Reply #5 on:
July 21, 2015, 06:21:31 pm »
Quote from: Vish8895 on July 21, 2015, 12:25:23 pm
Vish
See here
@Vish8895
http://www.mk5golfgti.co.uk/forum/index.php/topic,82040.msg877560.html#msg877560
Jknight89
Taking part
-Given: 2
-Receive: 1
Reply #6 on:
July 23, 2015, 02:46:17 pm »
It's a great idea and I'm very happy with how the car performs after R-tech worked there magic
goodsum
Can't Read PM's Yet!
-Given: 0
-Receive: 1
Reply #7 on:
July 23, 2015, 10:19:16 pm »
Nice starting figures. Do you have any other mods before the map? I'm presuming you're also using 5w40 oil now?
Jknight89
Taking part
-Given: 2
-Receive: 1
Reply #8 on:
July 26, 2015, 03:17:42 pm »
Only mods I had pre map were a ITG panel filter and pre cat delete. I will be using the millers oil on my next service.
All Things Mk5
R-Tech Zone
(Moderator:
rtechniki
