Author Topic: Wheel help please.  (Read 957 times)
Offline GTI 500
Wheel help please.
« on: May 04, 2015, 05:25:49 pm »
Looking at a set of 19" CHs, but they are 8.5x19 with an et of 35 or 45 with spacers. Will these fit my 58 plate GTI?? or will I have rubbing issues??
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Wheel help please.
« Reply #1 on: May 04, 2015, 05:46:55 pm »
You say et35 or 45 with spacers? If the wheels are et35 then any spacer will lower the offset. So an et35 wheel with a 10mm spacer gives a final offset of et25.
As for rubbing, it all depends how low you are. But at 8.5 wide I'd guess things could get a bit tight and you certainly wouldn't want spacers in the equation.
Offline jaffa
  • -Receive: 44
« Reply #2 on: May 04, 2015, 05:54:17 pm »
Et45 with no spacers and 225/35
Or et35 with 215/35 camber and rolled wings to stop the rubbing
Get the et45 and if you want then you can add spacers
Offline GTI 500
« Reply #3 on: May 05, 2015, 10:58:22 am »
Thanks guys.
