Author Topic: Mk5 GTI - Is it my regulator, motor, or wiring? Please help  (Read 1131 times)
Offline v1kkm
Hello,
My golf appears to have issues with the driver side window. When i hit the switch to put it down/up it makes the noise for a split second but then nothing happens. I've checked the fuse and all ok. The passenger window is fine.
Any ideas what it could be? Where could i start in diagnosing this issue?
Thanks,
Vik
Offline v1kkm
Re: Mk5 GTI - Is it my regulator, motor, or wiring? Please help
« Reply #1 on: June 26, 2015, 10:00:12 am »
Anyone?  :scared:
Offline MrACD
« Reply #2 on: June 26, 2015, 04:50:59 pm »
Got access to VCDS?  Start with that.
Could be a relay, the switch itself, something jammed.  Does the window drop if you hold the unlock button on the remote fob?
Other than that, take the door card off and take a look at anything obvious, the motor may have given up the ghost.
2005 Gti - 5dr, DSG, Black
2003 Toyota MR2 Roadster, Chilli Red
2005 Honda VFR800 Vtec
