Author Topic: Boxster 986 pads to anti-rattle /damper shim fitment?  (Read 3264 times)
Offline AIR_CHILLED
« on: June 11, 2015, 07:36:27 pm »
Hello, I have just taken delivery of some 986 Pagid pads from Eurocarparts along with some 36/40mm anti rattle shims which fit into the respective Pistons.
The pads already have standard Pagid dampers adhered to the back of each pad so do I pull these off to fix the Porsche ones on or just stick the Porsche dampers / anti-rattle shims over the top??
Your help is appreciated, preferably before the weekend lol!
Mike.
Offline bacillus
  • -Receive: 453
Re: Boxster 986 pads to anti-rattle /damper shim fitment?
« Reply #1 on: June 11, 2015, 10:34:40 pm »
Can you post a pic of the back of the pad to show these Pagid dampers?
Offline AIR_CHILLED
« Reply #2 on: June 12, 2015, 07:49:43 am »
Yes will do when I get to work.
FYI they are typical shim / dampers as found on most manufactured pads.
Offline bacillus
  • -Receive: 453
« Reply #3 on: June 12, 2015, 11:12:34 am »
Reason I asked is my pads have a plain back that I just glued/taped the anti rattle pads on to...
Offline AIR_CHILLED
« Reply #4 on: June 12, 2015, 01:24:01 pm »
Thanks for your replies bacillus, please see imgaes below:
As you can see the pads have a standard looking vibration / damper / shim thing attached, do I pull this off?
Also see above a picture of the Porsche shim with a adhesive backing.
Regards,
Mike.
« Last Edit: June 12, 2015, 03:00:39 pm by AIR_CHILLED »
Offline bacillus
  • -Receive: 453
« Reply #5 on: June 12, 2015, 08:04:21 pm »
Hmm, if you could cleanly remove that anti-squeal/rattle pad then I would do so. As you can tell the boxster anti-rattle shim needs a flat and clean surface to adhere to and I suspect that just sticking it on to those pads (as is), will make the fitting too thick with a 25mm disc.
Offline AIR_CHILLED
« Reply #6 on: June 13, 2015, 03:21:25 pm »
My thoughts exactly, it would be too thick especially as my discs are fairly new.
I will find out once I start the install and make a decision then.
I'll either pull them off or wait until the pads / discs are worn down slightly and if they turn out not to squeal I'll just save them for the next set of pads, win-win.
« Reply #7 on: June 13, 2015, 03:23:01 pm »
I would leave that pad as is.... and just put the shim ontop!
Offline AIR_CHILLED
« Reply #8 on: June 14, 2015, 09:16:48 pm »
Hi, fitted these brakes today and with the Pistons pushed back fully there was enough clearance to fit the pads as is.
Porsche shims were smeared with Pagid Cera-tec grease then fitted into the caliper Pistons before bolting them to the adaptors.
No brake squeal or vibration whatsoever.
Thanks for reading,
Mike.
