Author Topic: PCV Valve - Discrepancies  (Read 4645 times)
Offline LiamGTi
« on: June 26, 2015, 09:48:39 am »
Hi All,
I have read 10's of threads about PCV Valves, and I still do not understand the concept due to so many discrepancies.
I have a late 2006 Golf GTi - BWA Engine Code. I have no idea the Part number of the PCV fitted to my car at present.
I read this thread ( http://www.mk5golfgti.co.uk/forum/index.php/topic,44709.0.html ) which stated I needed these 3 items.
06F 129 101 G for the New breather valve PCV
06F 103 215 A for the pipe with checkvalve
06F 103 483 E for the Gasket
I ordered them from TPS - PCV Valve is now all superseeded to a Rev R. Pipe with Check valve is superseeded to a Rev B. Gasket remains the same.
All good right? However this is where the threads about PCV Valves and Pipes contradict. Some say you need the rear breather if you have the latest PCV in order to work, other say the latest PCV has the Rear Check Valve so no need to fit the pipe.
A simple question is I have all 3 parts, Obviously the PCV and Gasket need fitting - Do I, or do I not, fit the rear breather pipe with check valve (06F 103 215 B) If I fit Rev R PCV?
Threads with the info are here
http://www.mk5golfgti.co.uk/forum/index.php/topic,43801.30.html
http://www.mk5golfgti.co.uk/forum/index.php?topic=86443.0
Thanks all,
« Last Edit: June 26, 2015, 10:32:51 am by LiamGTi »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0npuhhctllbp4qhba0l10jnvmq&/topic,90967.msg917089.html#msg917089
Re: PCV Valve - Discrepancies
« Reply #1 on: June 26, 2015, 10:57:52 am »
I have recently fitter PCV version R. My car does not have a valve in the rear breather tube (its still the original).
05 | Tornado Red | DSG
Offline LiamGTi
« Reply #2 on: June 26, 2015, 11:02:31 am »
So do you think the best/safest solution is.
Fit Rev R - Check the Breather pipe if it has check valve then replace pipe, if it doesnt have check valve then leave it be.
What year is yours Dazza? Also was that smooth grill okay?
Offline Matthewsimone
  • -Receive: 39
« Reply #3 on: June 26, 2015, 11:09:39 am »
Im confused also to be honest mate
Hence why ive not replaced mine
Mine is 57 plate currently has rev R pcv fitted so am i to assume i woukd just need a new rev R pcv and gasket and job done?
Nothing wrong with car currently but for £41 a wouldn't mind replacing it anyway just as a matter of course due to the pcv being a commin known issue on the tfsi  :happy2:engines
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: June 26, 2015, 11:24:00 am »
Mines an 05 AXX. Getting the pipe of the rocker cover is a pita. Maybe the part number of the PCV will help u work out if u have a rear breather?
Or i may be wrong version R needs the rear breather??
The smoothed grill is great!  :happy2:
  • -Receive: 39
« Reply #5 on: June 26, 2015, 11:41:58 am »
How much is the gasket from tps/dealers?
Just looked on ebay and people want £19 for it  :sick:
Offline LiamGTi
« Reply #6 on: June 26, 2015, 01:14:05 pm »
Yeah it looks a nightmare if im honest! I'll check the PCV part number when it comes off. It sure looks good, glad you're happy with it!
Offline LiamGTi
« Reply #7 on: June 26, 2015, 01:14:51 pm »
Just bought one this morning from TPS - I think it was £16.80 + VAT. I know right.
Offline Norfolk boy
« Reply #8 on: June 26, 2015, 01:31:09 pm »
I'm new to VW's as only bought mine 3 months ago but can I ask what problems do these PCV valves give & why are you changing them?
Offline MrACD
« Reply #9 on: June 26, 2015, 04:40:32 pm »
@Norfolk boy This should give you a bit of info on it :)
2005 Gti - 5dr, DSG, Black
2003 Toyota MR2 Roadster, Chilli Red
2005 Honda VFR800 Vtec
Offline Norfolk boy
« Reply #10 on: June 26, 2015, 08:42:54 pm »
Thanks :happy2:
