Author Topic: Mk6 climatronic in golf mk5 gti  (Read 10625 times)
Offline K9
  • VW LifeStyle
« on: July 02, 2015, 07:20:18 pm »
is this the correct panel that i need plus the surrounding?
5K0907044 BT for the panel?
car is a 2005 gti dsg with rcd510 fitted and heated seats
Offline K9
  • VW LifeStyle
Re: Mk6 climatronic in golf mk5 gti
« Reply #2 on: July 03, 2015, 08:46:35 am »
What does that automatic air recirculation function mean?
Writen with my fingers
Offline mvb12
  • -Receive: 64
« Reply #3 on: July 03, 2015, 03:06:52 pm »
I have a MK6 climatronic unit if you need.
PM Me  :happy2:
Offline K9
  • VW LifeStyle
« Reply #4 on: July 03, 2015, 03:42:30 pm »
PM Me  :happy2:
@mvb12  u got Pm bud!  :happy2:
Offline K9
  • VW LifeStyle
« Reply #5 on: July 05, 2015, 05:26:27 pm »
bump.
Anyone know if it Req. anything more then a new mk6 surrounding and a mk6 climatronic panel part. nr 5K0 907 044 ES
what about the pin swap from 16 to 20?
I have a oem rcd510 installed with a gateway part nr. 7N0 907 530AL will it display on the rcd510 when doing changes on the panel?
What about the heated seats as now it's 5 speed and new one is 3 speed? do i need to do any tweakings on VCDS with that or will it work just fine?
And what about VCDS basic settings etc?
Please help asap
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: July 05, 2015, 09:53:18 pm »
You need to do the pin swap and code the panel. The coding is simple, just need to select the option with no sensor if you haven't fitted the AQS.
Then you need to reset the panel and check if your AC compressor starts and if your air recirculation works. You can also change the temperature from Fahrenheit to Celsius or vice-versa, depending on the settings that you need and that your panel is set. There are DIY online on how to retrofit the panel that explain all these questions. :wink:
I have heated seats too and they work without needing any other fiddling.
Offline K9
  • VW LifeStyle
« Reply #7 on: July 05, 2015, 11:47:10 pm »
Great! Thanks you! Can you please link me the DIY where it explane about displaying on rcd510? Easy to do the pin swap?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #8 on: July 06, 2015, 12:27:32 am »
http://www.mk5golfgti.co.uk/forum/index.php?topic=78320.0
http://forums.vwvortex.com/showthread.php?4938269-OEM-MKVI-Climatronic-on-a-MKV-on-a-RNS-510-Screen-installed
http://www.r32oc.com/topic/39962-golf-mk6-climatronic-in-a-golf-mk5-displaying-on-a-rns510/
The RCD-510 displays the climatronic changes automatically, so you don't need to worry about that.
It was a friend of mine that did the pin swap (and the OPS sensors, the RVC, door warning lights, rear footwell lights, and Bluetooth loom update). For him it's very easy... :laugh:
Offline K9
  • VW LifeStyle
« Reply #9 on: July 06, 2015, 12:51:04 am »
Readed somewhere that pin 16 and 20 are not the same bases or pins. Or will 16 fit in 20 place if removed the whole pin? Or do i need to cut them both?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #10 on: July 06, 2015, 07:58:07 am »
They're not the same size so need cutting.
VCDS (Preston, Lancashire)
Offline Softishman
« Reply #11 on: July 06, 2015, 11:22:32 am »
Or getting a loom fron a golf mk6 where the pins are correct size and colour on the cables...
Did this to be able to switch back to mk5 clima easy!
The left connector is mk5 and right mk6.
« Last Edit: July 06, 2015, 11:28:53 am by Softishman »
Offline Softishman
« Reply #12 on: July 06, 2015, 11:27:34 am »
Here is the cable you don'r re cinnect, black/green
Offline K9
  • VW LifeStyle
« Reply #13 on: July 06, 2015, 03:50:57 pm »
what do you men by mk6 loom? should i do like you if i want to switch back to mk5 climatronic when selling the car?
Offline Softishman
« Reply #14 on: July 06, 2015, 10:47:00 pm »
When i bought my mk6 clima panel i got the loom from tha car (mk6) aswell, i took the cable with rightcolour and right type oc vonnector and soldered it the my mk5 loom as pictured! Now it is really easy ti switch back again if tou want to!
