Author Topic: idle issue  (Read 724 times)
Offline Bane
  • "I was born a handsome man and now I'm half a goat
idle issue
« on: July 05, 2015, 05:36:27 pm »
The idle speed on my Edition30 has is not stable.
I noticed this yesterday,whilst sat a a junction.At first,I thought water had gotten into a sensor,as it was very wet here but after leaving it overnight and trying it this morning,I got the same result.
On starting the engine this morning from cold, it did what it normally does-went to around 1100 rpm and once the autochoke came off settled back to around 850rpm.
Then,as the temp went up the revs built up to 2000,dropped back to 1100 and then stated to pulse between 1000 and 1400 rpm and will do this constantly on idle.
ther doesn't appear to be any power loss on driving and no lights are lit on the dash.
I've checked the DV and no problems there.While running,I removed the oil cap and it ran rough and lumpy,so I don't think it's the PCV,although I haven't checked it properly.
Is there an ISV on these engines or am I looking at an air pressure leak somewhere in the turbo piping?
If anyone has any other ideas,I'd be happy to hear them. :happy2:
Oh,and I don't have access to VAG-COM before anyone mentions it. :wink:
Offline Ricky123
  • -Receive: 27
Re: idle issue
« Reply #1 on: July 05, 2015, 08:59:43 pm »
I would replace your PCV if you haven't fella. There's a very high chance it's that and the symptoms you describe , sound exactly to be that. :happy2:
+1 had similar problem on my last Gti and it was the pcv
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
Offline sanj
  • -Given: 17
Re: idle issue
« Reply #2 on: July 05, 2015, 09:06:07 pm »
As other's have said it will be more than likely your PCV as my Golf R did the same thing and I crapped myself,took it to my local indy who knew what it was straight away! :happy2:
Offline Daled0111
  • -Given: 26
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,95386.0.html
Re: idle issue
« Reply #3 on: July 09, 2015, 11:01:19 pm »
yep :happy2: pcv valve
