Author Topic: HPFP Noise  (Read 5919 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=1ijad043je6nfa0l3eep0u884l&/topic,90967.msg917089.html#msg917089
HPFP Noise
« on: July 06, 2015, 03:45:56 pm »
We all know the TFSI engines have a tapping noise from the HPFP area.
I recently listened to a 2008 GTI the noise was much quieter than on my car.
History
The follower when i purchased the car  :sick:
Cam Lobe.
Cam lobe after a bit of a polish
New follower at 2000 km
The follower at 5000km/1 year
Is there anything that would cause the noise to be louder? Faulty hpfp pump/spring or cam lobe??
In the last service i changed the oil pickup pipe and switched to millers nano drive so i'm hoping next service the follower looks better.
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #1 on: July 07, 2015, 12:50:45 am »
Before i DIY the intake cam.  :scared:
I'd like to try switching out my HPFP. Does anyone have a spare HPFP they can loan me? (i will cover the shipping) If it solves the noise i will gladly buy it.
I don't really want to fork out on a new pump chasing a noise which is probably normal.
I've also read that the n80 purge valve can make a noise but from the videos i've seen its much easier to spot.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=1ijad043je6nfa0l3eep0u884l&/topic,19740.0.html
Re: HPFP Noise
« Reply #2 on: July 07, 2015, 02:51:43 am »
@olethalb might have one
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
Re: HPFP Noise
« Reply #3 on: July 07, 2015, 08:39:33 am »
i my have one you can try dazza
 have a peak at this for an idea of the swap
http://forums.vwvortex.com/showthread.php?5934227-A4-DTM-2.0T-FSI-S3-intake-cam-swap
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline GTIEagles
Re: HPFP Noise
« Reply #4 on: July 07, 2015, 08:47:33 am »
That's interesting. I wonder if mine isn't right either.
I replaced my cam follower a couple of months ago and what I noticed is that there is an intermitant ticking that comes and goes around the HPFP area. I would say that 80% of the time it is ticking away and then it goes completely silent for a few seconds and returns again. Does this sound right?!
Offline schmidt_vr6
Re: HPFP Noise
« Reply #5 on: July 07, 2015, 11:51:35 am »
I've always thought the noise is coming from the timing chain. The TFSI do tend to sound like diesels on tick over though
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #6 on: July 07, 2015, 12:20:20 pm »
Thanks mate that doesn't look to bad providing i don't snap the bolt holding the adjustor like last time. The cam in that link looks really fooked mine has the newer cam.
I touched the N80 valve and it made a different noise. I will try replacing this first.
I've already replaced the cam chain, tensioner and adjustor this got rid of the diesel noise this is a tapping noise and i don't think its the injectors. May be the follower hitting the lobe as it does seem to be wearing quicker than others i have seen.
Offline Rob.
Re: HPFP Noise
« Reply #7 on: July 07, 2015, 01:36:38 pm »
I've got a couple of stock HPFPs if you need to borrow/buy one?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #8 on: July 07, 2015, 02:31:50 pm »
@Rob. that would be great! If mine is fooked how much would u want for a HPFP?
Offline Rob.
Re: HPFP Noise
« Reply #9 on: July 07, 2015, 04:15:27 pm »
£75 posted?
  • -Receive: 690
Re: HPFP Noise
« Reply #10 on: July 07, 2015, 04:58:39 pm »
The pump drive lobe doesn't look too clever tbh, which could be eating the coating off your followers.
After 8,000 miles with a Loba pump, there was no wear at all on the coating when I checked it.  I only mention Loba as it's stiffer spring puts more pressure on the follower / drive lobe.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #11 on: July 07, 2015, 05:11:49 pm »
£75 posted?
How about i give u a £75 deposit? If i'm being paranoid and the pump makes no difference i will return it and you can take the shipping charge from the deposit?
The lobe is on my todo list. I recently listened to a 2008 gti with 80,000 km it was way quieter than mine. I keep homing in on a noise from the HPFP area. (not the chain diesel noise)
I've ordered a new purge valve which can be noisy but mine is throwing no errors.
Offline Rob.
Re: HPFP Noise
« Reply #12 on: July 07, 2015, 10:55:45 pm »
That's fine by me. I take it you need it pretty urgently? Send us a PM
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #13 on: July 07, 2015, 11:20:30 pm »
Thanks mate. PM on its way.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: HPFP Noise
« Reply #14 on: July 07, 2015, 11:47:19 pm »
@olethalb been looking again at your cam swap in the audi. What i posted earlier is wrong the adjustor is not removed you just slip the chain off after you have removed the cam box? I felt confident replacing the chain when the cams were locked. Any special tools needed to replace the cam?
