Author Topic: Revo intake question?  (Read 1368 times)
Offline Bish155
« on: July 11, 2015, 11:12:17 am »
Just had my Revo camcoat intake fitted, but have noticed that where the intake pipe goes through the box it has a cut out in the top, is this right?
« Last Edit: July 11, 2015, 11:16:57 am by Bish155 »
Edition 30, Helix Clutch, pipercross panel filter, pipewerx Downpipe & Sports cat (200 CEL), R-Tech stage 1.5 linear map:314bhp & 321 Ib/ft, Audi S3 front brakes, H&R springs
Offline bigeyd
  • -Receive: 31
Re: Revo intake question?
« Reply #1 on: July 11, 2015, 12:26:01 pm »
Should be like that
Offline bigeyd
  • -Receive: 31
« Reply #2 on: July 11, 2015, 12:27:28 pm »
Unless it has worn through rubbing on the divider,if so get your money back as thats no good.
Offline Beej
« Reply #3 on: July 11, 2015, 12:42:21 pm »
My revo intake doesn't have a hole for the pipe to go through, it is shaped for the pipe to fit in. Makes sense, as if you need to remove the intake you don't have to remove the divider too
Offline bacillus
  • -Receive: 451
« Reply #4 on: July 11, 2015, 01:04:26 pm »
Sounds like you have the later revision divider/heat shield.
Offline Bish155
« Reply #5 on: July 11, 2015, 01:10:15 pm »
I have the same as you. Thanks for the replies guys.
Offline Bish155
« Reply #6 on: July 11, 2015, 04:40:03 pm »
I have just looked at the old elbow joint which the breather pipe connects to, has a very small amount of oil residue on the inside. Is this a worrying sign?
