Author Topic: Radiator fan pulsating  (Read 1744 times)
Offline Daled0111
  • -Given: 26
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,95386.0.html
« on: July 11, 2015, 06:12:16 pm »
The fan is pulsating when I lock my car anybody got any idears
Offline doylebros
  • -Receive: 310
Offline Daled0111
  • -Given: 26
Re: Radiator fan pulsating
« Reply #2 on: July 12, 2015, 10:41:41 am »
Have scanned it at work with our snap on top of the range scanner but there are no codes stored
Offline doylebros
  • -Receive: 310
« Reply #3 on: July 12, 2015, 10:57:43 am »
With the engine running and the aircon on low are both fans running?
Offline Daled0111
  • -Given: 26
« Reply #4 on: July 12, 2015, 03:28:54 pm »
yh think so
Offline Daled0111
  • -Given: 26
« Reply #5 on: July 12, 2015, 09:27:03 pm »
Yes both fans kick in when turn aircon on and then they go off when I turn it off
Offline doylebros
  • -Receive: 310
« Reply #6 on: July 12, 2015, 09:34:29 pm »
Assuming there's plenty coolant and your thermostat and inline stats are ok I would look at the auxiliary coolant pump
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/33-WATER-Electric_Coolant_Pump_Replacement/33-WATER-Electric_Coolant_Pump_Replacement.htm
With VCDS you can run and test the pump in output test etc and check system values for temperatures.
Offline Daled0111
  • -Given: 26
« Reply #7 on: July 12, 2015, 11:48:15 pm »
Just done a battery test with a computer from work and it says bad and replace
Would this have anything to do with it
