Author Topic: Private Plate  (Read 4277 times)
Offline irish_ram
  • -Given: 200
Private Plate
« on: July 27, 2015, 09:11:02 am »
Hi All,
A bit of a random question but hope someone can help.
My Wife has a Private plate which we have retained off a Vehicle we are getting rid of so the original registration has been allocated back to the Vehicle.
The problem she has is the car was registered to our old address which we do not have access to so the new V5C which I presume was automatically sent out when the Car Reg changed went to that address.
Now she has the old V5C which has our previous address on and also the private plate reg.
My question is if she fills out section 7 I think it is with her new address and sends it off, will the DVLA check the car details and realise the new V5C also need the reg changed aswell as her address details. Or will they just change her address and then send her a new V5C but it will still have the private plate on?
Thanks for any help in advance
Re: Private Plate
« Reply #1 on: July 27, 2015, 09:15:03 am »
 :happy2: Might be worth giving them a ring
Offline irish_ram
  • -Given: 200
Re: Private Plate
« Reply #2 on: July 27, 2015, 09:23:03 am »
Yeah that was my first thought but there is more chance of finding the Loch Ness monster  :confused: than getting through ot these people. Going to try them again this morning but thought I owuld see if anyone had the same situation on here.
Re: Private Plate
« Reply #3 on: July 27, 2015, 09:27:50 am »
There are a few private plates on here so hopefully get a reply soon
Kam88
Re: Private Plate
« Reply #4 on: July 27, 2015, 09:51:38 am »
never had an issue like that call them up they are getting much better at answering phone and being more helpful  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vi29lc2dmj6sdvb1kt938ver9u&/topic,19740.0.html
Re: Private Plate
« Reply #5 on: July 27, 2015, 09:56:12 am »
Hi All,
I would say yes they will. If you send the V5 back (filled in with change of address) with the V750 then I think that should be fine. As above tho, best to call to double check
Re: Private Plate
« Reply #6 on: July 27, 2015, 10:03:46 am »
Ive got a new plate lined up, I hope it goes smoothly
Offline Dan648v
  • -Given: 28
Re: Private Plate
« Reply #7 on: July 27, 2015, 10:04:25 am »
Yeah I would call then your not doing anything you don't need to. And potentially not have docs sat in the post that you need access to  :happy2:
They've been pretty good the times I've called them to sort out my private reg
Offline Dan648v
  • -Given: 28
Re: Private Plate
« Reply #8 on: July 27, 2015, 10:05:39 am »
New plate transfers are easy Mike  :happy2:
You shouldn't have any probs, usually takes a week or so to get the docs back once the transfers done
Offline irish_ram
  • -Given: 200
Re: Private Plate
« Reply #9 on: July 27, 2015, 10:52:06 am »
Just rang and go through to them and was simple actually. I just need to send off the V5C with a new address filled out and then a covering letter exlaining it also need to be revereted back to it's original plate but they said can take up to 4 weeks so will see.
Offline Skylinegtr
Re: Private Plate
« Reply #10 on: August 03, 2015, 10:49:03 am »
It should come back soon :happy2:
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Private Plate
« Reply #11 on: August 04, 2015, 10:09:30 pm »
If it isn't TF51 MKE you need to have a look at yourself
PLANS: Stage 2+
Re: Private Plate
« Reply #12 on: August 05, 2015, 07:04:16 pm »
I dont think thats available :-(   TF51 MKF  is the nearest available to that
« Last Edit: August 05, 2015, 07:06:39 pm by Tfsi_Mike »
Offline doylebros
Re: Private Plate
« Reply #13 on: August 05, 2015, 07:19:32 pm »
If you can't get through to DVLA try one of those number plate selling sites they get plenty issues like your to sort :happy2:
Offline AMV
Re: Private Plate
« Reply #14 on: August 08, 2015, 02:34:23 pm »
Give them a call i find that lunch time is perhaps the best time when i had issues with my private plate.
