April 10, 2025, 04:11:24 am
All Things Mk5
Mk5 General Area
Headlights problem
Topic: Headlights problem (Read 1498 times)
Remon_uk
Just Arrived
-Given: 0
-Receive: 0
Headlights problem
August 02, 2015, 08:17:34 pm »
Hi all,
I have a problem with my headlights, over the last two three years my headlights have started getting worse, not sure if it's mist or cracks or a chemical or what. Has anyone else had this problem? VW Hvae advised to replace them both, obviously lol. I want a cheaper option Atif anyone knows a quick fix ?
Thanks guys
Andy
Admin
Just look at my post count
-Given: 39
-Receive: 443
Re: Headlights problem
Reply #1 on:
August 02, 2015, 08:28:57 pm »
You can buy head light restorer at halfords and it works a treat
gttdi build thread
r32 build thread
Washout
Always Involved
-Given: 5
-Receive: 13
Reply #2 on:
August 02, 2015, 09:21:28 pm »
This one on ebay is the one that people have had good results with. Remember it removes the protective uv coating so you will need to put a seal/protectant on them.
http://m.ebay.co.uk/itm/251749289972
white91
Won't Shut up.
-Given: 10
-Receive: 13
Reply #3 on:
August 02, 2015, 09:24:25 pm »
Get a machine polisher
SRC
Always Involved
-Given: 21
-Receive: 27
Reply #4 on:
August 02, 2015, 10:14:43 pm »
I can't tell from the pictures - is it external or internal?
External - use one of the headlight restorers, which involve polishing the surface.
Internal - you've most likely got a faulty seal, probably around the bulb holder.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods: Seat inserts and a VW bottle opener. Each worth 20bhp.
Skylinegtr
Just Arrived
-Given: 0
-Receive: 0
Reply #5 on:
August 03, 2015, 10:35:09 am »
A good buff will bring them out like new
percy
Always Involved
-Given: 1
-Receive: 6
Reply #6 on:
August 03, 2015, 12:16:32 pm »
3m do a good headlight restoration kit around £20 mark, also guides on YouTube showing how to do it and it works great . If you do you use one of these kits then make sure you cover the engine bay with a cloth as the residue that splatters up is a pain to get off.
Remon_uk
Just Arrived
-Given: 0
-Receive: 0
Reply #7 on:
August 06, 2015, 08:47:09 am »
Thanks guys for your help, I brought Meguires restoration kit from eBay, worked well...
GTIEagles
Won't Shut up.
-Given: 10
-Receive: 22
Reply #8 on:
August 06, 2015, 09:28:16 am »
Another tip, make sure you put plenty of tape round the bumper because when I did mine the disc kept slipping off and consquently cut into the paint work of the bumper a few times
Personally if I was to do mine again I would remove them and do them on a bench, that way you can get right to the edges without fear of damaging your paint work.
xjay1337
-Given: 15
-Receive: 377
My Ride:
Reply #9 on:
August 06, 2015, 11:05:53 am »
Quite common on a lot of cars...
We tape them up. Generally start at 1000 grit and work up to 3000 then compound and polish.
Click for build thread
Stage 2 GTI Purple Scene Queen
221bhp/365lbft TDI build
Detailing Guide
Wheel Fitment Guide
All Things Mk5
Mk5 General Area
Headlights problem
Jump to:
=> Mk5 General Area
