All Things Mk5 => Mk5 General Area => Topic started by: captainsherlock on September 29, 2015, 10:16:33 am
Title: Gear lever play
Post by: captainsherlock on September 29, 2015, 10:16:33 am
Hello,
When in gear the level has a large amount of play in it if you choose to move this back and forth (it is solid otherwise). As the GTI is still under warranty I am going to pop it back yet any ideas as the potential cause / fix?  Would you deem this a warranty issue?
Many thanks.
Title: Re: Gear lever play
Post by: Scottymon on September 29, 2015, 10:49:57 am
Could be the gear linkage and or bushes on them, you can kind of reset them, theres a YT vid about it, or upgrade the bushes for a firmer feel.
It could also be the in the cabin the gear lever, has a plastic bit that wears over time and can cause similar issues.
If its under warranty worth having a chat with them. :happy2:
Post by: captainsherlock on September 29, 2015, 11:06:00 am
Thanks for this - if not under warranty what sort of costs are we talking about?
Thank you.  :smiley:
Post by: PT82 on September 29, 2015, 11:50:05 am
I had same issue. Fitted a quickshift and some draft design bushes and this made the world of difference.
Post by: scopes on September 29, 2015, 11:52:29 am
For the bush under the gear stick about £3.00... 15 mins to fit, you may need an extra hand to help you with this.
If i remember correctly about £40.00 odd quid for the 42dd bush kits in at the linkages, just make sure you order the correct bushes, as they can be easly mixed up...  A photo always helps of your old bushes...!
Try @vRSAlex (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=1981)  at aks tuning for the bushes... or awesome GTI
A short shifter and side to side shifter will tighten things up also...
Post by: white91 on September 29, 2015, 12:44:01 pm
Do you have a part number for the bush under the gear stick?
Post by: scopes on September 29, 2015, 12:50:33 pm
Not Handy, but it will be somewhere in this forum...
I'll ask the search button .... :laugh:
Post by: scopes on September 29, 2015, 12:53:58 pm
http://www.mk5golfgti.co.uk/forum/index.php/topic,96931.msg960570.html#msg960570
Post by: PT82 on September 29, 2015, 12:55:23 pm
I bought one and it wasn't the cause of the issue. If I still have it I will send it to you if you're u like.
http://www.mk5golfgti.co.uk/forum/index.php/topic,97809.0.html
Post by: GTIEagles on September 29, 2015, 01:09:42 pm
What was the issue with yours in the end? Mine has a bit of play but it's not as bad as yours!
Post by: scopes on September 29, 2015, 01:12:15 pm
That was the link i could not find...
Post by: PT82 on September 29, 2015, 01:25:02 pm
According to my mechanic (indie specialist) the bush wasn't the issue. Maybe a stretched cable somewhere. Put the eBay quickshift on and it is much better. Not fixed the original issue but got around it I guess. I ordered the wrong 42 draft design bushes. My car is a 57 reg but a 2008 car. I ordered 2007 bushes. Yet to fit these as its a 70 mile round trip to garage I use.
Post by: white91 on September 29, 2015, 04:00:10 pm
I've ordered one from TPS now else I would have had it.
Did you end up using the 42DD bushes as mine is a 2005, I will need some when I fit my quick shifter.
Post by: PT82 on September 29, 2015, 04:55:51 pm
Not on the car yet buddy. Will have them fitted next time the car goes into the garage. I got them from Awesome GTI  :happy2:
