All Things Mk5 => Mk5 General Area => Topic started by: Janner_Sy on December 28, 2009, 12:03:12 am
im seriosuly thinking of getting a k04 at some point in the future to be honest, but i dont have the cash to foot for the whole shebang in one lump, so im looking @ picking up all the ancillaries in dribs and drabs, like a bit a month. then ill hold out for a second hand k04.
anybody know the going rate for the ancillaries needed and alternatives available :
1)Injectors
2)Dv relocation kit.-What other options are there for the DV relocation?
3)DOes the throttle body/intercooler pie need replacing
3)I presume all i need to change on my intake is the pipe leading to the turbo for the DV take off?
i have a broken k04 that i'll be getting fixed in spring and probably selling on depending how much it costs to fix.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi715.photobucket.com%2Falbums%2Fww160%2Fjakethemoss%2FDanishK04rebuild.jpg&hash=af8e85446197b872a57808c9d8f082dcc0b8a35b)
These are the parts needed
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fww160%2Fjakethemoss%2Fk04kitwithpartnumbers.jpg&hash=7dddbd7891912432207403b49b9ce89cc20122a0)
And here are the part numbers :santa:
looking at that, it doesnt seem to bad.
questions though.
I take it the discharge pipe from the k03 cannot be used for the k04 then, i was under the impression it was just the throttle body pipe. are there aftermarket versions available for the k04?
can the k03 d revision DV still be used with the k04
Have you costed any parts up yet Sy?
Mine didnt come with the little boy :P
questions though.
It's only the silicone hose that has a bigger diameter, the alutubing is the same.
The company the rebuilt mine, are working on an aftermarket part for the K04 including a small twist :wink:
As soon as i have time to spare they will test it on my car :jumping:
As long as your Dv isn't defect you can reuse it :santa:
emails have been sent out, i can get hold of second hand S3 injectors. turbos crop up all the time on ebay, plus cuprak1 is starting a vag parts thing in the new year iirc so ill also contact him for some prices
