All Things Mk5 => Mk5 General Area => Topic started by: Kieran1990gti on March 08, 2016, 11:37:38 am
Was looking into buying a loba hpfp but is it a direct replacement for my original pump with the banjo bolt setup or would it require a delete and set up with the bamboo style
The bamboo connector on the loba pump screws into the pump and can easily be unscrewed and swapped for your original banjo bolt.
I wonder if they give you the option as the union brass connector and banjo bolt is £40 from vw
