All Things Mk5 => Mk5 General Area => Topic started by: Gmac on April 21, 2016, 03:13:15 pm
Title: Tyre size question..18"
Post by: Gmac on April 21, 2016, 03:13:15 pm
Quick question...
I'm planning new putting H&R lowering springs on and also putting a set of 18" wheels on which are 8j wide..
They come with 235/40/18 tyres... I know normally we'd be looking for 225, but will the 235 cause any rubbing issues????
TIA
Title: Re: Tyre size question..18"
Post by: pudding on April 21, 2016, 03:39:35 pm
It might throw the speedo out a little as the sidewall height is a percentage of the width.
Post by: jayha11 on April 21, 2016, 03:58:59 pm
Few things that will help:
Whats the offset of the wheels?
Are the springs 30mm drop?
Post by: Gmac on April 21, 2016, 07:10:37 pm
The offset is et43, and the drop is indeed 30mm...
Post by: jaffa on April 21, 2016, 10:21:18 pm
Probably rub with the 235's
Doing the screw mod will give you a few mm's clearance but you should get some 225's
Post by: sub39h on April 21, 2016, 10:37:33 pm
I do agree that you should run the right size tyre, but the difference is negligible - 4mm radius or less than 1mph difference at 70mph
http://www.brspecialtuning.co.uk/Tyre%20size%20calculator.htm
Post by: jayha11 on April 22, 2016, 10:44:15 am
Just to give you some perspective I am running the following...
18x8j ET35 (stick out 8mm further than yours)
lowered approx 65mm front & back
Tyre's are 215x40x18 to aid with tucking at the rear
Is there a specific reason you want to run 235 tyre's?
Post by: Gmac on April 22, 2016, 11:27:12 am
Yeh, the wheels that are for sale come with 235's.  I've currently got 17" wheels and tyres.
Post by: Gmac on April 22, 2016, 11:27:59 am
Will do a search for the 'screw mod'.  :happy2:
Post by: pudding on April 22, 2016, 11:59:43 am
Yeah it's very minor usually, but sometimes one tyre maker's '235' is a bit different to another's.   I usually find taller tyres than standard affect the gearing and unsprung mass more than anything else though!
