All Things Mk5 => Mk5 General Area => Topic started by: Blackgtiman on May 23, 2016, 10:46:59 pm
Title: r-tech remap clutch help
Post by: Blackgtiman on May 23, 2016, 10:46:59 pm
hello all,
just had a stage 1 r-tech remap on my 2007 60k miles mk5 gti. (255/320) less than 24 hours in and the clutch is slipping in 6th.  :sad1:
what do I do?
1.ask r-tech to turn the torque down
2. fit a new oe luk clutch
3 fit a new oe clutch and flywheel
4 fit a uprated clutch.
5. drive around it as the clutch was fine on oe power and only slips due to the high torque in 6th.
I'm a bit lost as to what to do as I want the car to be right but don't want/have the money to have to fork out as I had not expected the oe clutch to give in so easy (silly me for not doing the research I guess)
andy
Title: Re: r-tech remap clutch help
Post by: tigamilla on May 23, 2016, 10:50:00 pm
How can you tell it's slipping in such a high gear?
Sent using Tapatalk
Post by: slix on May 23, 2016, 10:56:23 pm
Drive up a steep hill and floor it in a higher gear and see if it still does it.
Post by: Blackgtiman on May 23, 2016, 11:01:03 pm
if I put the car in 6th at 60mph and floor it, it slips (ie revs rise)
Post by: tigamilla on May 23, 2016, 11:30:57 pm
R-Tech told me they deliberately derated mine to 246/295 to make it clutch friendly - but I think that's because mine is quite a senior GTI,  so they probably thought best be safe.
The ooomph from that keeps me grinning like an idiot with no slippage as you've described it so if you did back to them you know that's a viable option...
Sent using Tapatalk
Post by: r5gtt on May 23, 2016, 11:49:06 pm
I'd replace the clutch if I had to but I'm dsg  :signLOL:
Post by: dansmith180 on May 23, 2016, 11:54:40 pm
Its perfectly fine to leave it for now, not really dangerous. Just don't floor it at low RPM's or launch and it should be fine and will probably last for months. Then replace with an uprated one would be my choice. Really depends if you plan on keeping the car long or modding further etc...
Post by: Dan_FR on May 24, 2016, 07:39:02 am
Drive around the issue (i.e. drive it properly and rev the thing!) until you have the money to change the clutch and DMF. If sticking with stage 1 or stage 2 then a standard one is fine..... Parts are around the £300-350 mark, plus labour
Do you not have switchable maps?
Post by: Greenman on May 24, 2016, 10:18:52 am
I have r-tech stage 1 at 268/334 and get no clutch slip.
I think i'm just lucky, or i just don't push it enough.
If it were me i would upgrade clutch to something that can take the extra torque so that you have piece of mind.
Post by: Madone on May 24, 2016, 10:22:41 am
You def don't need a updated clutch at stage 1 or 2 on a K03 car. I am on stage 2+ on a edition 30, aroubd 370bhp on a new standard clutch. It's done 5k without issue.
Post by: Blackgtiman on May 24, 2016, 10:29:34 am
Thanks for the replies. I did ask for switchable maps but nik said my ecu would not take them. Im waiting for nik to come in today to speak with him regarding the issue. I dont really want to go down the upgraded clutch path but i also dont want to put another luk in and still find it slips.
Post by: Dan_FR on May 24, 2016, 11:55:33 am
It will not slip on a new standard clutch. Mine started slipping at about 50k miles on stage 1, changed it out for a new LUK standard clutch and DMF
Unless you heavily abuse it, a new clutch will last a long time. I'm stage 2+ with WMI now, so been at all stages since the clutch went in 12-13k miles ago....... all ok so far but I don't launch it or load it up in high gears
Post by: r5gtt on May 24, 2016, 02:05:54 pm
I'm with Dan_FR on the luk clutch as I replaced mine on the previous motor before a remap as it was slipping at two years after ownership. After the map I did abuse the car to some extent but within moderation as it was pride and joy :signLOL: Clutch was still strong when I sold it to the chap who came from Newcastle.
Performance clutch tend to wear quicker from what people have told me so I'd stay safe and go for OEM. some cars have 350 bhp one oem clutches  :grin:
Post by: AJP on May 24, 2016, 02:39:56 pm
I was in a similar position. Decided to go for an uprated clutch instead of oem, just in case I decide to go further than Stage 2 in the future.
Post by: MC71 on May 24, 2016, 05:39:31 pm
@Blackgtiman (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=11816)
Fit an uprated Organic clutch combined with a OEM DMF (personnal preference Id recommend Helix so speak to Alex at AKS Tuning). I ragged the hell out of my 2+ Eddy for 3 years and the Helix Clutch was immense.
Post by: AJP on May 24, 2016, 05:43:58 pm
Yep, I love mine. For a few extra quid I know it'll take everything the BWA will be able to throw at it.
Post by: Madone on May 24, 2016, 05:55:28 pm
You definitely don't need an updated clutch, standard will take all a mapped K03 can muster (if you don't go silly and perform constant traffic light starts). Standard clutch drives nicer than a heavier updated version.
Post by: Wolf Burger on May 24, 2016, 07:09:17 pm
I've been looking at an uprated clutch for my Mk6R any reason for the Helix over a Sachs one?
How heavy do you find it over standard???
Post by: Blackgtiman on May 24, 2016, 09:41:10 pm
A few different reply's there, thanks.
r-tech have agreed to put a new map on with less power/torque. Ill see how that goes and when/if it slips again ill to go for a luk clutch and flywheel from carpartsforless. I really don't want to spend out on uprated parts or change the feel of the clutch.
Post by: Octoparrot on May 24, 2016, 10:44:34 pm
Is it just me that is surprised it slips in sixth and not in the lower gears?
Post by: dansmith180 on May 24, 2016, 11:41:16 pm
No that's when it usually happens, high gear - low rpm's. All the torque puts lots of strain on the friction plates, when in lower gears it spins more freely and so doesn't slip or slips much less.
Post by: MC71 on May 25, 2016, 11:26:12 am
@Wolf Burger (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=4479)
No reason for Helix over the Sachs alternative other than Alex at AKS recommended it and that is and was good enough for me. Plus I had my Eddy's torque taken up to 420ft lb while having the 2+ map done by Niki a few back and it was still holding strong........as I said.........immense clutch (had it taken back down to 370ft lb as not to tempt fate).
Post by: Wolf Burger on May 25, 2016, 11:49:47 am
Thanks for the info!
I am just worried about how heavy an uprated clutch will be!! Were you DSG?
Post by: MC71 on May 25, 2016, 12:15:03 pm
Manual.
After first having it fitted it was no more than approx 30% heavy but soon bedded in and was no heavier/stiffer than the previous OEM feel. Overall a much better feel IMHO.
Post by: Blackgtiman on May 25, 2016, 09:36:23 pm
what sort of money are the upgraded clutchs? carparts4less do the luk one for a very good price of 125!
Post by: MC71 on May 26, 2016, 09:06:39 am
Have a look at a previous GB Alex at AKS did, similar prices these days I imagine. Should be able to get an uprated Organic clutch (plus fit a new DMF at the same time) and fitting for all under £1k so not to bad.
~~ Clicky here ~~ (http://www.mk5golfgti.co.uk/forum/index.php/topic,82207.0.html)
Post by: Dan_FR on May 26, 2016, 12:12:56 pm
OEM LUK clutch, DMF and CSC = £325 ish quid from Carparts4less with discount codes applied
Uprated Helix item and new DMF = RRP £880+ apparently, although seen plenty obtain them for the £750 mark.... still double the price when it isn't needed at Stage 1
Post by: Blackgtiman on May 26, 2016, 12:36:07 pm
thanks dan, yes big jump in price. best price I got on CP4L is 380 for clutch, fly, slave and bolts. I used code clutch10
Post by: Dan_FR on May 26, 2016, 01:08:58 pm
Their prices are high at the moment, higher than usual - probably because they're offering the 10% clutch code
£380 is still a lot better than the RRP of £880. I'd wait it out or shop around elsewhere
Just checked Eurocarparts...... Clutch, DMF, flywheel bolts and a new CSC (you need all of this) is currently £364.92
