All Things Mk5 => Mk5 General Area => Topic started by: K9 on June 21, 2016, 07:01:23 pm
Title: Skyline mod question
Post by: K9 on June 21, 2016, 07:01:23 pm
hey, does anyone do the skyline mod shown in this page http://www.golfmkv.com/forums/showthread.php?t=42586&page=44 on post #960?
need some advices from someone who have done it thx :)
Title: Re: Skyline mod question
Post by: JoeDarKa on June 21, 2016, 07:03:28 pm
I did it ages ago and it looked pants
Post by: K9 on June 21, 2016, 07:13:16 pm
how come? pics? how did you secure the bulb when drilled the hole?
Post by: r5gtt on June 21, 2016, 07:45:28 pm
The bulb style doesn't look as good as the rings K9
Post by: K9 on June 21, 2016, 07:51:52 pm
what rings do i need to use?
Post by: MateyGuv on June 21, 2016, 09:27:31 pm
First pic on this link is what 90mm LED Angel eye rings look like http://www.mk5golfgti.co.uk/forum/index.php/topic,69555.45.html
Iv been working on this mod for a while and come up quite a few issues that I wasn't happy with but found solutions for most of them. Still working out the final problem but life has caught up with me so it's on the back burner for a while
Post by: K9 on June 21, 2016, 11:37:46 pm
What problems do you have?
Skickat från min SM-G935F via Tapatalk
Post by: r5gtt on June 21, 2016, 11:39:38 pm
I sent you the link and nw MateyGuv has sent the same.
Post by: MateyGuv on June 22, 2016, 12:22:31 am
Depending on what you'll accept on your car will depend if the issues Iv had will concern you but some if my problems were...
Finished look after taking the lens off, colour match of outer and inners, half brake to full circle brake to quad brake, heat issues with wiring, resistance with wiring, bulb out warning light, colour warmth of inners, dark/light spots in inners, electronics, clean power supply to LED's etc etc. I didn't want an it'll do set up so kept going to what I have now. Find me on Instagram and Youtube under the same username as there is quite a lot of info there.
If your desperate for quad lights there is a chap on Facebook who is using my first method that'll take some money from you to do a version of the skyline mod.
Just saying ---> https://instagram.com/p/BBdRFlUL938/
Post by: K9 on June 22, 2016, 08:54:38 am
I want to try to wire up 2 w5w bulbs inro the housing first. But unsure that do i need a resistor or not? And should ibdrill a hole just big enough for the bulb to fit into it and the glue it there? And whwre can i take power for them to turn on with the ingnition?
Post by: MateyGuv on June 22, 2016, 11:23:07 am
Fitting bulbs is a waste of time in my opinion as it looks very very different to the outers. I didn't even try that method as Iv seen them and I didn't like the end result. @JoeDarKa (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=3709) has tried that method so he may be able to assist  :happy2:
Post by: cenobytez on June 22, 2016, 12:32:19 pm
there is a guy on facebook who does the mod, he sends you out a set of lights with LED rings fitted with wires out the back, look for Mk5 golf skyline modded lights. Ric is the guys name
Post by: JoeDarKa on June 22, 2016, 12:35:33 pm
If you just put 2 bulbs in, you will get 2 very obvious bright spots with darker spots too. It looks rubbish.
Post by: JoeDarKa on June 22, 2016, 12:41:17 pm
http://www.mk5golfgti.co.uk/forum/index.php/topic,30209.420.html
I also had to cut away part of the metal in the boot so i definitely wouldnt bother! I had the skyline rings but they kept steaming up whilst cleaning it so went back to standard
Post by: cenobytez on June 22, 2016, 12:53:11 pm
yeah, thats why you need the LED rings...
Post by: JoeDarKa on June 22, 2016, 12:55:50 pm
I did the led rings too which steamed up so got rid of them...
Post by: RetroRaz on June 22, 2016, 12:59:50 pm
I've tiger sealed mine with 3 layers. Never split or steamed
Post by: K9 on June 22, 2016, 02:12:27 pm
what did you use? leds or rings?
Post by: MateyGuv on June 22, 2016, 02:14:14 pm
LED rings mate. Look on eBay for 90mm red Angel eye LED rings  :happy2:
Post by: JoeDarKa on June 22, 2016, 04:29:32 pm
I think i used some type of black sealant used for bathrooms
Post by: K9 on June 22, 2016, 06:20:21 pm
like these ? http://www.ebay.co.uk/itm/161364249255?_trksid=p2055119.m1438.l2649&var=460386974985&ssPageName=STRK%3AMEBIDX%3AIT (http://www.ebay.co.uk/itm/161364249255?_trksid=p2055119.m1438.l2649&var=460386974985&ssPageName=STRK%3AMEBIDX%3AIT)
Post by: K9 on July 01, 2016, 11:50:08 am
ordered these 90mm red ones http://www.ebay.co.uk/itm/112013630443?_trksid=p2057872.m2749.l2649&var=410952898152&ssPageName=STRK%3AMEBIDX%3AIT
