All Things Mk5 => Mk5 General Area => Topic started by: fazi123 on July 09, 2016, 10:50:26 pm
Hi Guys,
I'm going to be purchasing some coilovers in the coming weeks and I wanted to renew/refresh the top mounts while I was at it.
Could anybody confirm which top mounts both front and rear I could upgrade to? I hear the RS3 / TT mounts are a good upgrade. Can anybody confirm the part numbers or just which model car I should be searching for when looking online?
Thanks in advance,
Faz
If you aren't fused about adjustable top mounts, then yeah RS3 is probably best option.
I have everything needed still in packaging for the front if you want to buy them from me, as I'm getting adjustable ones, so have no need for the RS3 ones anymore.
If you want adjustable top mounts, then you need to look at VWR or Ground Control top mounts.
Cheers mate. How much are you after for your setup?
Sorry to hijack the thread @fazi123 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=9745) :drinking:
Just wanted to know what part numbers they are please?. @Adam0604 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=12798)
Part numbers:
8J0 412 331 - Strut Mount x2
6N0 412 249 C - Bearing x2
N 910 216 01 - Nut x2
N 101 277 07 - Bolt x6
£75 for the lot @fazi123 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=9745) ?
If he doesn't want them I'm here :jumping: @Adam0604 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=12798)
Part numbers:
Cheers @Adam0604 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=12798)
Can you hold onto until Wednesday for me? I want to find out from a cousin of mine about whether I should go with the adjustable variants or not.
Thanks in advance,
Faz
Yeah not a problem.
Hi, is it an advantage to change to RS3 top mounts at the rear as well as at the front?
Brendan
@Adam0604 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=12798) did you get my PM bud?
