All Things Mk5 => Mk5 General Area => Topic started by: poko on January 28, 2010, 12:02:12 pm
Title: 225X40X18 or 255X35X18
Post by: poko on January 28, 2010, 12:02:12 pm
Hi ,
I am soon going to replace the tires on my leon cupra.
car will be tuned to approx 450+ HP
I want to get the best performance and handling i can get.
for some reasons i have only two tire options right now ,both are TOYO R1R
the first is to stick with the original 225X40X18 and the second is to move to 255X35X18.
running over 2deg camber front and rear
i had various opinions , and i really can't decide.
i cannot do it in a trial and error fashion since obviously i will need different rims and to buy the two different sets of tires.
what do you think ?
Title: Re: 225X40X18 or 255X35X18
Post by: danishmkvgti on January 28, 2010, 12:06:55 pm
honestly?? 255 would be my choice  :happy2:
Post by: poko on January 28, 2010, 01:13:48 pm
the main questions about the 255's are :
1) will they fit ? r1r's are very wide.
2) the contact patch is larger , however the weight on each square centimeter is lower , therefore i am not sure how good it is.
of-course if looks were an issue,  255's will be much nicer.
Post by: Lyons on January 28, 2010, 01:17:38 pm
What width are the wheels?
Post by: Hedge on January 28, 2010, 01:19:09 pm
Check JonnyC's build thread as he has just fitted 255's.
I don't think it is as straightforward as you would like.
Post by: poko on January 28, 2010, 01:42:42 pm
current are 7.5X18
for 255's i will go for 9X18 et42 or maybe 8.5X18
Post by: poko on January 28, 2010, 01:43:11 pm
will look , very hard to find something in the 100+ pages build thread.
Post by: Hedge on January 28, 2010, 01:45:23 pm
I appreciate that so I did it for you.
http://www.mk5golfgti.co.uk/forum/index.php?topic=679.msg166657#msg166657
Post by: Lyons on January 28, 2010, 01:53:37 pm
current are 7.5X18
For 8.5 or 9 i'd go for 255.
Post by: poko on January 28, 2010, 03:39:07 pm
thanks.
looks like it should fit.
especially as it looks like he is not running camber currently and with a -2 degrees it will be even an easier fit.
i will just have to find the right rim for it , quite hard to do so in israel.
but still , the question is if there is any performance downside except for the increased drag.
Post by: Hedge on January 28, 2010, 03:59:19 pm
I'm pretty sure he is running camber.
There had also been some gentle caressing of the wheel arch looking at it on Sunday.  :wink:
Post by: Hurdy on January 28, 2010, 08:10:28 pm
Yeah, Jonny is definitely running camber.
Me too soon :innocent:
Post by: jonnyc on January 28, 2010, 08:34:43 pm
If your going with 255's you need the following.. And anything else you will seriously struggle to make them fit.. (bare in mind this is all on a Golf too) I dont know if there is much difference in arch clearances on the Cupra, I know there was with the S3..
* Heavily modified arches all round, cut away bumper support brackets, rolled lips, removed arch liners, pulled LOTS
* Wheels specs need to be 18 x 8.5 / ET50 (48 at a minimum)
* 1.5 degrees front camber or more, 2.0 degrees rear or more (bare in mind you cant get away with as much with a 255
* Also, im not sure on strut diameters of the different coilovers, mine are H&R's and Im running 1mm clearance on the front, 2mm rear..
If you do all of that then you will be able to get a 255 on..
Good luck  :happy2:
Post by: poko on January 28, 2010, 08:59:15 pm
thanks for the replies.
Jonny, what was the difference in clearance between the S3 and Golf ?
i have not tested, but by the looks of it the Cupra looks to have a little more space.
when cornering hard do you get any rubbing ?
(it will be used on KW Clubsports with camber plates).
also , how do you compare cornering capability and feedback from the wheels compared to the previous 225X40 ?
i am interested in maximum track performance, care a little less about straight lines.
Post by: jonnyc on January 28, 2010, 09:04:45 pm
Its awesome on the 255's.. Lots more grip as you would expect but still within the capability of the stock suspension geometry.. (I was a little concerned they may be too much) But bare in mind that the TT comes with a 255 section tyre its not so bad.. I want to run 275's in the future..
No rubbing what so ever..
The S3 has roughly 3-4mm more arch clearance than the Golf..
Post by: poko on January 29, 2010, 12:50:34 pm
it looks like too much of a job after looking at it today.
what do you think on 245X40X18 ?
will the extra height be a problem
Post by: jonnyc on January 29, 2010, 12:54:21 pm
3 options if you want to stay with stock rotational diameter.. 225/40 255/35 or 285/30
I have ran 235/40 and that's ok, only a few mm but 245/40 would be daft..
Post by: Hedge on January 29, 2010, 04:30:02 pm
Any use?
335 25/18, diameter diff: -1.96% , speedometer will read faster than actual.
  155 55/18, diameter diff: -1.49% , speedometer will read faster than actual.
  285 30/18, diameter diff: -1.41% , speedometer will read faster than actual.
  245 35/18, diameter diff: -1.33% , speedometer will read faster than actual.
  215 40/18, diameter diff: -1.26% , speedometer will read faster than actual.
  145 60/18, diameter diff: -0.94% , speedometer will read faster than actual.
  175 50/18, diameter diff: -0.78% , speedometer will read faster than actual.
  195 45/18, diameter diff: -0.71% , speedometer will read faster than actual.
  295 30/18, diameter diff: -0.47% , speedometer will read faster than actual.
  255 35/18, diameter diff: -0.24% , speedometer will read faster than actual.
225 40/18
  165 55/18, diameter diff: +0.24% , speedometer will read slower than actual.
  305 30/18, diameter diff: +0.47% , speedometer will read slower than actual.
  205 45/18, diameter diff: +0.71% , speedometer will read slower than actual.
  185 50/18, diameter diff: +0.78% , speedometer will read slower than actual.
  265 35/18, diameter diff: +0.86% , speedometer will read slower than actual.
  155 60/18, diameter diff: +0.94% , speedometer will read slower than actual.
  235 40/18, diameter diff: +1.26% , speedometer will read slower than actual.
  145 65/18, diameter diff: +1.33% , speedometer will read slower than actual.
  315 30/18, diameter diff: +1.41% , speedometer will read slower than actual.
  275 35/18, diameter diff: +1.96% , speedometer will read slower than actual.
  175 55/18, diameter diff: +1.96% , speedometer will read slower than actual.
Post by: poko on January 29, 2010, 05:12:50 pm
335/25/18 it is  :laugh:
Thanks for the help
I will do the change approx in a month
Ill set up one wheel in 255 and if i cant sort it on the cupra revert to 225 in r888
