All Things Mk5 => Mk5 General Area => Topic started by: JoshJaggard on March 05, 2017, 12:28:15 am
Has anyone had a carbon clean done?
If so, was it worth it?
I believe the general consensus is it's not worth it.
Walnut blasting seems to be the method everyone recommends - I've been looking to get mine done but can't find anyone local in Leicester who does it.
x2
I believe R-tech offer a similar service.
Yeah R-Tech do walnut blasting, probably cheaper than most places too as they can probably strip the TFSI with they eyes closed and one hand behind their back :grin:
I didnt think R-tech did any mech. stuff.
I had my GT TDI carbon cleaned about a year ago and could tell the difference immediately! Saying that though, a GTI would have a lot less build-up than a high mileage diesel like mine.
I didn't think r tech offered this service - will give them a shout
I Dont think they do....
They do mate. I spoke to niki lastweek and i'm booked in for the start of april
OK must be a new thing then.
What do they charge for walnut blasting? I didn't ask last time I was there
Yeah rtech do it and replace seals etc for £325 I think Niki said on fb, believe they're offering it now they're getting new premises :happy2:
I have just spoken to rtech now and can confirm the above - £325 for walnut blasting and need to leave the car with them (as expected)
Wonder if they've ever done a before and after dyno run?
I can't remember exactly but i'm sure its £450 including the runner flap delete supplied and fitted.
...... just seen the posts about price after i wrote this.
Cleaned valves won't give you any more peak hp. At best you can expect slightly better cold starting and perhaps a slight improvement in off boost responsiveness.
Carboned up valves remind me of skidded pants. Not pleasant to the eye and whilst the skids don't affect anything, you just know they are there and want them gone.
Seen on another thread someone who had their S5 carbon cleaned
Whilst strapped on a dyno, with a before and after run
Without being moved the whole time
There was an increase of around 20bhp with a print out
The old n'asp V8 S5, or the more recent turbo one?
You will defo get gains on n'asp engines as they ingest a fixed amount of air. And it's got 8 sets of valves clogging up, which when summed together is a lot more of a restriction compared to 4 sets of valves on a 4 pot turbo engine.
It's getting on for a £400 job on the TFSI, which is too much money for such a tiny gain.
If someone did some MAF logging at idle, part throttle and WOT and found an increase in air flow being pulled in under all those conditions, I'd probably do it, but if the engine runs smoothly and is quick, I'd leave it personally.
I'm not sure where you got £400.00 from to clean the inlets. Most places charge around £150.00 to do the inlet cleaning, Rtech are offering to have your injector seals changed as well as flow tested, I believe that is where the £300+ figure is coming from
im yet to hear of a company offering walnut blasting for £150
R-Tech are now offering walnut blasting service and will be carrying out other mechanical soon as their new unit is up and running or have already started the mechanical
Re the £150 job...
Sure we're comparing like for like?
Ie not comparing terraclean or some such similar chemical process (imho a waste of time/money for these cars) v walnut blast or mechanical cleaning?
I think runner flap delete may even cause slightly lumpy cold start/idle. So I'm told by a reliable source with firsthand experience.
If everything is kept clean I personally don't think it's necessary, just my opinion of course. :laugh:
I was going by the £360 that AKS charge, which is 'getting on for £400' in my book, especially when you factor in the petrol getting there and back, plus any other little bits and pieces that might need doing whilst they're in there.
That does seem to be the word on the street! I can understand why. Loads of fuel being chucked in so the atomization is poor, so the flaps do the 'crimping the end of a garden hose' thing to accelerate the air to introduce swirl. Neat trick.
They also work when hot to improve low end torque, so that probably suffers too, especially on laggy KO4 engines.
My K04 with RFD achieves maximum torque at 2500 rpm. I wouldn't consider that a very laggy turbo. I removed the RF mostly to avoid future issues if any would break and damage the engine. I don't get a lumpy start and the slightly lumpy idle is only noticeable if you really pay attention for enough time.
The turbo is spooled by 2500rpm, I'm talking about the rpms from idle up to 2000ish. The flaps and cam advance definitely help with responsiveness down there.
I didn't drive mine long before removing the flaps but I'm not sure if the difference is really noticeable once you remap the ECU. It's much more responsive now. :smiley:
I'm having quite a serious issue with this. To the point where I get the dreaded oil pressure stop lights, my mechanic is telling me to get rid of the car. I want to keep her though, will walnut blasting resolve my problem?
getting mine done on saturday from elite carbon clean seen an advert on facebook 2 cars for £99... will let you know the outcome
Ok thanks mate you got the same problem? ?
If you look at page 17 of the PDF you will see how little the flaps are actually used.
http://www.volkspage.net/technik/ssp/ssp/SSP_337.pdf
Anything more than idle or cruising and they are open/non-functional and nothing but a restriction.
Interesting. They work over a wider rpm range than I thought. Niki said he's seen them open / close at various loads and rpms.
Not much of a restriction though, in comparison to the other restrictions dotted around the engine. Intercooler, turbo scroll, port divider plates, etc etc. Niki said the flaps cause no 'restriction' issues unless pushing be 380hp.
I was going to say that :laugh: :rolleye:
If that's the S5 that was "engine carbon cleaned" at Surrey rolling road, that'll be the "Italian tuning" effect of revving the car and getting the upstream parts of the exhaust nice and hot during the process that resulted in the extra power. There is no cleaning going on at the inlet valves.
Please have a look at my vid, and read the comments:
There's something I read somewhere, probably in the handbook, that strongly suggests that regularly driving at a higher rpm to build cylinder temps up and EGT's is a good thing to for the TFSI engines. You can use these cars without abusing them, treating them too conservatively isn't good for them.
The inlet system will always be flawed but add into the mix short journeys, an engine oil that might not be as good as it could be, cheap/low octane fuel, driven to mildly and extended servicing the outlook will be much worse I'm sure.
