All Things Mk5 => Mk5 General Area => Topic started by: bullzeye on May 10, 2017, 03:33:12 pm
Title: mk5 GT TDI 140, VCDS
Post by: bullzeye on May 10, 2017, 03:33:12 pm
Hi guys, just got myself a mk5 gt tdi 2007, facelift.
wanted to scan it with vcds but cant find my engine code (1k) in the drop down menu, am i using the wrong version of vcds 1.2 lite?
Title: Re: mk5 GT TDI 140, VCDS
Post by: Christiank on May 10, 2017, 07:19:30 pm
Make the autoscan from the Can?
Post by: bullzeye on May 10, 2017, 11:40:44 pm
No idea what that is chris, i just checked each control module and the only thing i could pick up was the engine,  which had no faults, i have been through every other entry, like radio, but it tries 4 times then says error.
Post by: Christiank on May 11, 2017, 12:12:10 am
Hm.. Got some pictures if the screen you're getting? And is it an original Ross Tech cable?
Maybe your canbus is f***ed if it doesn't answer the VCDS. - You do turn on the ignition when you connect the cable right?
Post by: bullzeye on May 11, 2017, 01:07:23 am
I can get some pics tomorrow, the lead i use was just a cheap one off ebay, i used to use the same lead on my mk4 gti, dident have any problems, and yes, the ignition is on when trying to scan, i can scan the engine module, but any of the others just time out
Post by: mrxbox360 on May 11, 2017, 01:30:29 am
Unless its a genuine cable you have very limited functions due to mk5 being full canbus systems
Post by: Christiank on May 11, 2017, 08:33:30 am
Yeah would also say it's the cable or the canbus there isn't working.
The can bus can get toasted, I know from expience.. But it's not likely that this is the problem with you.
Source someone out with a genuine cable and try get them to scan and see if the problem is still there.. If it is - Then i got a "AM" revison canbus you can buy ;)
Post by: bullzeye on May 12, 2017, 01:41:56 pm
Is anyone from Lancashire area, willing to scan the car for me? i dont mind to travel a little bit, as long as its not to far :)
Any help much apreciated.
Thankyou
Post by: ChrisGT on May 12, 2017, 07:39:13 pm
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
Chris
Post by: bullzeye on May 12, 2017, 08:40:58 pm
Thanks Chris I'll msg guy from Preston now :happy2:
Post by: ChrisGT on May 12, 2017, 09:07:52 pm
No worries, I don't think the first post has been updated very recently so if you can't get hold of them then there may be more people further through the thread that are close to you.
Chris
