All Things Mk5 => Mk5 General Area => Topic started by: oisinc on May 11, 2017, 05:47:26 pm
Title: NGK PFR7B sparkplugs on a unmodified Pirelli?
Post by: oisinc on May 11, 2017, 05:47:26 pm
Just wondering If I can use the NGK PFR7B in a unmodified Pirelli?
Most threads seem to recommend them for tuned motors.
Dont want to put them in if they'll cause issues.
Title: Re: NGK PFR7B sparkplugs on a unmodified Pirelli?
Post by: ROH ECHT on May 11, 2017, 09:20:19 pm
I used them on the K04'd mk5 when I ran my DM tune. They are fine without mods...but oem shouldn't give you troubles either. Mostly the NGK PFR7B @ 0.028" are used when high PSI results in unexplained misfires and usually fixes them. I didn't need them with the K04 running the GIAC High Output file...but when I tried a DM tune running @ 26 PSI...misfires and those plugs worked. Now, back to running GIAC file, I'm back to using the oem plugs without issue.
Post by: pudding on May 12, 2017, 10:13:03 am
Just run standard plugs.  People seem to mess around with coils, plugs, plug gaps etc etc when there really is no need.
Post by: oisinc on May 12, 2017, 01:00:49 pm
What is the standard plug?
Sent from my ONEPLUS A3003 using Tapatalk
Post by: pudding on May 12, 2017, 02:00:16 pm
From the dealer.
Post by: ROH ECHT on May 22, 2017, 07:24:07 pm
If you have oem installed and still have issues...the problem likely lies elsewhere and is not the plugs.
