All Things Mk5 => Mk5 General Area => Topic started by: djhorace on February 04, 2010, 02:26:59 pm
As per title, does anyone else have this?
There is a thread over on SCN here - http://www.seatcupra.net/forums/showthread.php?t=244058
Nobody else got this?
I have a KO4 on my vRS and no i don't have that noise.
http://www.mk5golfgti.co.uk/forum/index.php?topic=11498.0
Not the same noise by the sound of it mate.
Just spoke to someone who reckons this could be the fuel truss sensor on the inlet manifold. The way he explained it, it goes away when the stock code is on the car which is exactly what happened to mine when I stripped it back last year to sell it.
I changed mine too, but for a different reason and to something different rather than OEM :innocent:
On the inlet manifold? I thought that was air inlet temp sensor.. Hurdy what have you in place?
yeah as did i, that is the MAP sensor(thrust sensor)
x2 what have you replaced it with hurdy
I think the map sensor is the one on the plastic pipe going to the throttle body.
OEM part is in front of me now.
06D 130 767C by KLN stamped on the side.
Still working through logs and set up to see if changing it helps.
It is the pressure limiting valve in the pic below.
http://daz.co/media/hh199/tbuccini/130bar_failure_Hypo.jpg[/img]"](https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fhh199%2Ftbuccini%2F130bar_failure_Hypo.jpg&hash=4d719d6ca85f9ed51284e0b504b19ba7b9121432) (http://"[img width=786 height=614)
Did anyone solved the partial throttle noise issue? Does the RS4 Fuel return valve solves the problem?
