All Things Mk5 => Mk5 General Area => Topic started by: maxamplitude10 on August 15, 2017, 08:49:23 am
Title: Clutch and DMF Replacement
Post by: maxamplitude10 on August 15, 2017, 08:49:23 am
Hi does £720 all in sound about right for a new OEM clutch, DMF, Slave cylinder and all bearings on my Edition 30?
Ta
Dean
Title: Re: Clutch and DMF Replacement
Post by: Cadders96 on August 15, 2017, 09:14:39 am
£800 at AKS tuning for a uprated clutch and OEM flywheel, have heard this is the one to go for and I am buying this later today, comes with
Helix Organic Or Paddle Drive Plate
Helix Billet Clutch Cover
LUK Slave Cylinder (Bearing)
AKS Custom Cover Genuine Bolts
LUK Flywheel And Flywheel Bolts *Optional* (When buying Flywheel)
Post by: maxamplitude10 on August 15, 2017, 09:20:35 am
Thanks for response
The £720 was a fully fitted and warrantied price I guess the gear your referring too is supply only?
If so how much do you expect to pay for fitting or are you planning on fitting yourself?
Tx
Dean
Post by: rcrmn on August 17, 2017, 09:00:56 pm
Hey Dean,
The garage that I usually use charged me £200 cash for the fitting of my Clutch, Flywheel and Release Bearing that I'd already bought from Darkside here (http://www.darksidedevelopments.co.uk/products/sachs-2-0-tdi-6-speed-02q-dual-mass-flywheel-and-clutch-kit.html)
I'd say around £200/£250 for fitting is usually around what it should be if you're supplying the parts :happy2:
Post by: maxamplitude10 on August 21, 2017, 08:42:23 am
Spot on then parts are £520 trade from MVC so £200 fitting costs:-)
TX
Post by: Cadders96 on August 21, 2017, 09:01:30 am
Hey Dean,
Does this include fluids or did they supply this?
Post by: maxamplitude10 on August 21, 2017, 10:16:40 am
Fluids including in fitting:-)
