All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Northern_ED30 on July 26, 2022, 07:35:04 am
Title: Emission control light after a spirited drive
Post by: Northern_ED30 on July 26, 2022, 07:35:04 am
Morning all,
Took the Ed30 out for a spirited drive yesterday and towards the end of the run the EML came on, unfortunately the tablet for my obd reader has decided not to work so I can’t can’t get any codes.
I’ve noticed that the car has lost a lot of power but the idle is stable which is making me think it’s the n80/blowoff recirc valve, does this sound probable?
It is mapped and research suggests those valves don’t hold up, is revision G the correct one to go for?
Title: Re: Emission control light after a spirited drive
Post by: Clarkj93 on July 26, 2022, 08:14:40 am
It could be in limp mode rather than just physically losing boost. Rev G is the correct DV to go for if replacing but bottom line is you need to get it scanned really before you start throwing money at parts.
Post by: Northern_ED30 on July 26, 2022, 08:46:15 am
Cheers Clark, got a mate with an code reader but have to wait until friday.
I don't think it's in limp mode as it lets me rev all the way round the clock still, might unplug the DV and see if it gains power back.
Post by: Clarkj93 on July 26, 2022, 09:00:34 am
Be careful unplugging the DV. I'm sure I read before that unplugging a turbo DV and then boosting can cause some serious issues for your turbo.
Post by: Northern_ED30 on July 26, 2022, 09:55:15 am
Yeah it can and will cause damage long term as it will cause compressor stall, for the purpose of a quick diagnosis I think it’ll be safe but if anyone advises against it then I will avoid  :happy2:
Post by: LC5F on July 26, 2022, 02:46:21 pm
if its a Bluetooth obd reader - in case the EML is gnawing at your brain - they tend to be easy to use with free phone apps
