All Things Mk5 => How to Guides / Troubleshooting => Topic started by: adamvaughan on December 22, 2022, 04:53:00 pm
Hello. I wonder if you can offer any thoughts on the issue I'm having with my 2.0 TSI Mk5 estate (BWA engine).
For context - It's a Japanese import and I haven't driven it a great deal since it landed. on first driving it would flash the engine light and go into limp mode when putting your foot down. Fault codes at the time saud coil pack so I replaced these on cylinders 1 & 2 (there was corrosion on the end of them).
Now it's still going into limp mode when you put your foot down. All boost drops off around 4000rpm and the fault code I'm getting says P0234 overboost condition. [
I've taken it to a couple of places to look at it. The first place replaced the MAF sensor and this didn't solve it. They then told me it likely needed a new turbo (£1600).I was reluctant to take them up on this as they were talking about vanes sticking in the turbo. I understood this was only an issue for the kind of turbos fitted to TDIs, is this correct?
The second place replaced the N75 valve and this hasn't solved it either.
I've pasted a couple of scans from below. The first is after the first place looked at it, the second after the second place. I've noticed now there is a fault code related to the MAF and one related to voltage. Could it be a voltage issue to the MAF sensor causing the problem? Where would I start in addressing this?
Any help is much appreciated
Sunday,04,December,2022,12:19:05:15724
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ9M256056 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9Mxxxxx Mileage: 65860km-40923miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWXBZ0I0020782
Coding: 040300431C070160
Shop #: WSC 01668 000 00000
VCID: 343112AB5238B96B33B-8060
VINID: 9E69EAAAA05BA89742146005181A2626EF
1 Fault Found:
000564 - Boost Pressure Regulation
P0234 - 001 - Limit Exceeded (Overboost Condition)
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 65854 km
Time Indication: 0
Date: 2000.00.00
Time: 16:43:24
Freeze Frame:
RPM: 2385 /min
Load: 95.3 %
Speed: 81.0 km/h
Temperature: 57.0∞C
Temperature: 14.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 051 C HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1817
Revision: 04843012 Serial number: 00000805030151
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 1373B13737765E534A1-8046
No fault code found.
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 133B600D09270000C80B06E9901F0081B500
Shop #: WSC 21882 003 1048576
VCID: 00598E7B5A00D5CBE73-8054
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 68
Mileage: 65720 km
Time Indication: 0
Freeze Frame:
Count: 2
Count: 12
Count: 13056
Count: 8193
Count: 42496
Count: 65280
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CT HW: 1K0 907 044 CT
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 7BA3F9973FE6B613B21-802E
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
01592 - Air Quality Sensor (G238)
014 - Defective
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000000986246
Coding: E78F0F2700041500470000001C00000000097F075C000120000000000000
VCID: 71BFDBBF6DAACC4318D-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 030708 021 0501
Coding: 00038805
Shop #: WSC 00066
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 200508 046 0204
Coding: 00208933
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 7F AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M05S52$
Coding: 0014150
VCID: 6C81CACB4A8821AB2BB-8038
Subsystem 1 - Serial number: 6332MSME33214B3CA
Subsystem 2 - Serial number: 6342MSME3A23060A6
Subsystem 3 - Serial number: 6351HSME165109571
Subsystem 4 - Serial number: 6361HSME162733651
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 051 0101
Coding: 0012142
VCID: 0451826B4218C9EBC3B-8050
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
5 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 864 A HW: 1K0 920 864 A
Component: KOMBIINSTRUMENT YJU 3905
Revision: V0010000 Serial number: VWXBZ0I0020782
Coding: 0007403
Shop #: WSC 15171 067 57207
VCID: 2A0D0CD380FCFF9B997-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 200508F2001609
Coding: ED817F060002022003
VCID: 35372FAF5942A063045-8060
2 Faults Found:
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 68
Time Indication: 0
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 28
Mileage: 65688 km
Time Indication: 0
Date: 2000.00.00
Time: 00:10:15
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO YJU 3905
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1520
Revision: 71009005 Serial number: 00000083388612
Coding: 0004790
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
1 Fault Found:
00750 - Warning Lamp
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Time Indication: 0
Freeze Frame:
Voltage: 10.50 V
PD
Temperature: 17.0∞C
RPM: 234 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 8090020052830C7F2D0484056008DF03E0FCA0
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 4
Reset counter: 67
Time Indication: 0
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1520
Revision: 71009005 Serial number: 00000530088610
Coding: 0005046
VCID: 72BDD4B368ACF75BE17-8026
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1D2AB12B8F96BF3B-8020
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003251623
Coding: 0000144
VCID: 75B7EFAF19C2E063C45-8020
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003204011
Coding: 0000144
VCID: 76B5E8A304C4EB7BCDF-8022
End----(Elapsed Time: 01:18, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Thursday,22,December,2022,16:08:46:15724
www.Ross-Tech.com
VIN: WVWZZZ1xxxxx License Plate:
Mileage: 65900km-40948mi Repair Order:
VIN: WVWZZZ1KZ9M256056 Mileage: 65900km-40948miles
42-Door Elect, Driver -- Status: Malfunction 0010
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 65854 km
Time Indication: 0
Date: 2000.00.00
Time: 16:43:24
Freeze Frame:
RPM: 3347 /min
Load: 100.0 %
Speed: 65.0 km/h
Temperature: 33.0∞C
Temperature: 3.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 65880 km
Time Indication: 0
Freeze Frame:
RPM: 137 /min
Load: 73.7 %
Speed: 0.0 km/h
Temperature: 20.0∞C
Temperature: 12.0∞C
Voltage: 9.652 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0∞C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0100 0100
Coding: 0000020
Revision: 00H45001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 68
Mileage: 65720 km
Time Indication: 0
Freeze Frame:
Count: 2
Count: 12
Count: 13056
Count: 8193
Count: 42496
Count: 65280
Count: 0
Count: 0
2 Faults Found:
014 - Defective - Intermittent
Coding: 00038805
Shop #: WSC 00066
Coding: 00208933
Shop #: WSC 00066
Coding: 0014150
Coding: 0012142
5 Faults Found:
00576 - Terminal 15
Coding: 0007403
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 68
Time Indication: 0
Freeze Frame:
Fault Priority: 1
Reset counter: 29
Mileage: 65688 km
Time Indication: 0
Date: 2000.00.00
Time: 00:10:15
Coding: 0004790
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 0 km
Time Indication: 0
Revision: 00H15000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Time Indication: 0
Freeze Frame:
Voltage: 10.50 V
PD
Temperature: 17.0∞C
RPM: 234 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 67
Time Indication: 0
Coding: 0005046
Coding: 0000003
Address 56: Radio
Cannot be reached
Coding: 0000144
Coding: 0000144
End----(Elapsed Time: 01:19, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
I've been also getting limp mode and the same error code P0234 overboost condition however have not had any error codes to do with MAF sensor or voltage, I'm planning on replacing the N75 as I have also received an error code for the N75 (P0243 - Solenoid Valve (A) for Boost Pressure Control (N75), Open / Short Circuit to Ground) as well as the diverter valve. If that doesn't work I'm not sure what to try next as a new turbo will be too expensive atm.
Replaced N75 and Diverter valve but still getting the overboost I think the turbos must be finished 😭
