All Things Mk5 => Mk5 General Area => Topic started by: jacksosi on April 16, 2023, 04:39:49 pm
Title: Boot won't close - Fixed
Post by: jacksosi on April 16, 2023, 04:39:49 pm
This has probably already been posted in the past, but I cannot seem to use the search function, so just in case...
Yesterday the boot suddenly would not shut.
A bit of Googling showed that I probably needed a new locking mechanism.
Only about £20 on Amazon, and same day delivery  :jumping:
Easy to remove/replace, just two bolts and a clip-on electric module.
All now sorted  :phew:, and probably only about 10 mins work if you have the tools and knowledge (2h for me as started from ground zero)
The only issue is now that the boot take quite a slam to engage, but I had that issue with the old lock too...so something probably need adjusting...a job for the garage next time it goes in.
