All Things Mk5 => How to Guides / Troubleshooting => Topic started by: sir.tshipo267 on February 05, 2025, 10:45:30 am
Title: Mk5 GTI 2.O FSI -AXX- Hard start, when it starts engine shaking + misfire,
Post by: sir.tshipo267 on February 05, 2025, 10:45:30 am
mk5 gti 2.0l AXX, went with it to work in the morning, the first start was a hard start but it started on the second try, i felt it was okay, drove to some locations and then parked it at work, all of a sudden when I knock off from work, car is cranking, the engine stalls, I tried another fuel pressure sensor and changing coils, still nothing, its even misfiring and engine is shaking, shows EPC sign, no power, i recently was fixing the timing chain replacement. Last time I diagnosed it showed code sign of camshaft positioning code
I am suspecting high pressure fuel pump. I am stuck, I don know what to do. Can anyone help me?
If you have whatsapp I can gladly show you what I mean.
Title: Re: Mk5 GTI 2.O FSI -AXX- Hard start, when it starts engine shaking + misfire,
Post by: jennybeaven on February 12, 2025, 02:25:29 pm
Hi there,
I've been having issues with Oil Pressure STOP coming on while driving. The engine sounds rough (rattling, missing) while cold but seems to get better when warmer. Oil pressure doesn't always come on. The code is P0011, we are suspecting this is the timing has skipped/ VVT gear related however I've stripped it down and the chain and follower looks fine.
Any other ideas on what this could be?
The sump has been stripped and cleaned previously as well.
