All Things Mk5 => Mk5 General Area => Topic started by: gti turbo on April 08, 2010, 08:56:38 am
Title: This noise is doing my head in now.
Post by: gti turbo on April 08, 2010, 08:56:38 am
Every time i get in to my car and switch ignition on theres a very loud cherping noise and its doing my head in coz dont know how to stop it.
Does anyone elses do the same,or does anyone know how to stop it?
Video of noise added.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi592.photobucket.com%2Falbums%2Ftt1%2Fmoondancer2009%2Fth_SAM_0107.jpg&hash=4b1d92a5fb9c74bbea2e1ccb320a4d88e75d3b57) (http://s592.photobucket.com/albums/tt1/moondancer2009/?action=view&current=SAM_0107.flv)
Title: Re: This noise is doing my head in now.
Post by: WhiteGTI on April 08, 2010, 09:21:09 am
Cherping? Is it a beeping? A Clicking? Constant, or Intermittent?
Post by: gti turbo on April 08, 2010, 09:24:46 am
It sounds more like a cherping mate. It does it about 6 times every time i switch ignition on.
Post by: andrewparker on April 08, 2010, 09:37:36 am
I actually have no idea what a cherp sounds like :laugh:
Post by: WhiteGTI on April 08, 2010, 09:40:13 am
^ Me too  :ashamed: :ashamed:
When you put the key into the ignition you will hear a "wirring" sound from the engine which is the throttle body aligning, and you may hear about 6-8 clicks as the air conditioning vents sort themselves out. As for a "cherping", i have no idea, sorry mate.
Post by: jeynesey on April 08, 2010, 09:44:51 am
Does it do it EVERY time?
Post by: gti turbo on April 08, 2010, 10:00:36 am
Yes everytime i turn ignition on.
Lets call the cherping a rite loud beeping sound then,not coming from the engine but through the speakers in the car.
The last owner had the parrot ck3000 fitted but took out the lcd disply that you answer calls with and left all the wires in could it be anything to do with that?
Post by: mohare on April 08, 2010, 10:19:28 am
Could be your timing belt
Post by: gti turbo on April 08, 2010, 10:21:03 am
Its not coming from engine. Its coming from speakers in the car.
Post by: WhiteGTI on April 08, 2010, 10:21:06 am
But its coming through the speakers of the car....
EDIT: Ahh you beat me to it!
Post by: jeynesey on April 08, 2010, 10:21:25 am
I would say possibly. Can you get a video of it on your phone or something?
Post by: mohare on April 08, 2010, 10:24:49 am
I would suspect the wires from the parrot ck3000.
Post by: cuprak1 on April 08, 2010, 10:43:36 am
have you have your lights on   :evilgrin:
Post by: cmdrfire on April 08, 2010, 11:51:48 am
The "bing bing bing bing bing"?
That's the seatbelt reminder/warning noise.
Post by: Richn83 on April 08, 2010, 01:04:31 pm
If its coming through the speakers could it be an earth issue?  related to the lose wires from the parrot, are the wires bare? if so they could have moved and be in contact with the metal of the body work?
Or a noise or interference supressor on the stereo, does the power on state of the stereo have any effect on the noise?
Post by: jhtrophy on April 08, 2010, 02:21:12 pm
Pop stereo out and pull wires from phone kit, 5 min job, will bw that
Post by: gaz b on April 08, 2010, 02:25:42 pm
Agreed. Try putting your seatbelt on before you turn on the ignition! :smiley:
Post by: stealthwolf on April 08, 2010, 07:25:54 pm
The seatbelt warning should only go off once you are above a certain speed.
Post by: gaz b on April 08, 2010, 08:03:41 pm
Mine gives it about half a dozen beeps, then stops. If I drive off without my belt on the beeping comes back.  :driver:
I just assumed all golfs did this? :surprised:
Post by: Hurdy on April 08, 2010, 08:23:03 pm
You can change the seatbelt settings with Vagcom to only "bong once you are over 10mph :happy2:
Post by: gaz b on April 08, 2010, 08:29:10 pm
Cheers Hurdy .  :happy2:
Might have to find somebody with vagcom. It is a bit of a pain in the hoop!  :ashamed:
Post by: cmdrfire on April 08, 2010, 10:35:19 pm
No, it's the seatbelt "reminder" that bings when you start the car.
The seatbelt warning which is the same noise activates over 10kph.
Either one, or both, can be turned off via VCDS. I keep it on as it tends to annoy passengers and makes them put their belt on.
Post by: pazz on April 08, 2010, 10:57:56 pm
I hope that was a joke...
Cause I found it pretty funny.
Post by: gti turbo on April 08, 2010, 11:55:52 pm
I hope it was too, :rolleye:
Anyway its not the seat belt sound its much more af a higher pitch sound. Will get a video of it at the weekend to give you all a much better idea.
Post by: stealthwolf on April 09, 2010, 02:11:28 am
Lol never realised, since mine was never activated in the first place  :signLOL:
Post by: gti turbo on April 10, 2010, 09:53:52 am
I have added a video of the noise.
Hopefully this will help.
Post by: T30GUE on April 10, 2010, 10:10:42 am
is your bluetooth enabled on your mobile? it may be the parrot thing trying to connect?
switch your phone off and try again maybe?
Post by: T30GUE on April 10, 2010, 10:14:10 am
Watched your video mate - That's nothing like the seatbelt alarms, or any noise that a golf should make - too high pitched and irritating to be OEM.
I would definately disconnect the parrot from the back of your stereo.
Post by: gti turbo on April 10, 2010, 02:29:01 pm
So we guessing its the parrot bluetooth then.
How do i get stereo out to disconnect the wires?
Its is annoying as hell,that noise happens everytime i switch ignition on.
Post by: VC on April 10, 2010, 02:34:02 pm
you have to gently pry away the surrounding trim and then you'll be left with a few screws around the stereo, once undone it will slide out and reveal the connections  :happy2:
...this is the point where i recommend some trim removal tools rather than a screw driver too  :smiley:
Post by: gti turbo on April 10, 2010, 04:37:28 pm
Right a little update on the annoying noise.
Took the stereo out and disconnected all the wires and put the radio on back seat,switched the ignition on and the f*cking noise is still there.
Cant understand coz it still coming through the speakers.  :evilgrin: :confused:
Post by: cmdrfire on April 10, 2010, 11:45:37 pm
Not sure how the Parrot is wired, but my guess is the entire unit needs to be removed as it probably gets it +12V on its own source and won't require the head unit to be installed.
That noise would do my head in as well.
Possibly an aftermarket immobiliser?
Post by: titchy on April 11, 2010, 09:21:49 am
if it was anything to do with the parrot surely it would be a squawk [sorry]
Post by: gti turbo on April 11, 2010, 09:57:58 am
 :signLOL:
But please dont spam my thread with stupid answers.
Post by: gti turbo on April 11, 2010, 10:04:10 am
I noticed when the noise happens phone comes up on the stereo display.
Also paired my phone up to the parrot bluetooth and when someone rings me it does actualy ring through the speakers,but coz i havent got the lcd display i cant answer the call and speak through the parrot handsfree.
Post by: Jono76 on April 11, 2010, 10:08:01 am
I used to get the same noise with my Octavia vRS when my Parrot kit was playing up!!
It wouldn't do it when the Parrot was working correctly only when it was faulty, I never got to the bottom of the fault before I PX'd the car.
If it was me i'd rip out the kit and bin it  :wink: :wink:
Post by: gti turbo on April 11, 2010, 10:30:39 am
Ive been reading on other forums and there should be a ble box with all wires connected to it.
Where would this be located?
Post by: Steve Baker on April 11, 2010, 10:39:38 am
This may help you find the offending loom ??  :wink:
http://www.parrot.com/documents/en/support/schemasdinstallation/pdf/wiring_vw_ac000018aa_1.pdf
Post by: boe3 on April 11, 2010, 02:37:39 pm
think your fine the noise is a parrot produced fault warning telling you its has a problem with the kit  (this being the display is not attached) i had this exact same thing happen to me with a part ex at my work either totally remove the phone kit or fit the missing part this will sort it
