All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: boe3 on April 11, 2010, 09:01:58 pm
hi guys have been running my ed 30 know for a while with apr stg1 and milltek non res cat back its running so well im loving the exhaust note when its spooling up just awsome but i am know considering a upgraded intake i am probably going to go for the itg intake,my question to you is will i need to have the map altered to allow for this or will i be able to just bolt it on and run it as i am, or possibley would i need anything else upgraded many thanks rob
It will show gains on the Stage 1 map just fine :happy2:
ok cool at this stage am i ok to run without uprated fuel pump
you should be @stage 1 mate with no issues. Who are you getting mapped with. you shouldnt even have issues at stage 2 with fuel cut if the tuners sets up the map right.
apr stg1 is for OE pump. it takes the mid range restrictions into account. so itll be fine.
you would go to other stages if you added a pump to make full use of it :happy2:
worth checking with apr as well though just to be sure.
^^^ as VrSy said.. :happy2:
yeah its apr stage 1 done by reubens at tuningwerks he did mention popping back to have it adjusted if i had a decat or highflow cat fitted but nothing about the air intake so think i will get one on order bring on more noise :happy2:
