All Things Mk5 => Mk5 General Area => Topic started by: scotta on May 03, 2010, 09:35:10 am
Title: Clutch slipping plus questions
Post by: scotta on May 03, 2010, 09:35:10 am
Clutch has started to slip between 3 - 4k in 4/5/6th. Car has only done 19.5 k!
Anybody know prices/options for replacements?
Running bluefin stage one at the moment - is it worth sticking the standard map back on?
Could i chance it with a warranty claim if i stuck the standard map back on?
When you return the bluefin to standard does it flash the vag code back on or is it a superchips emulation of standard mode?
Any comments/suggestions welcome.
 :sad1:
Title: Re: Clutch slipping plus questions
Post by: MAT ED30 on May 03, 2010, 09:38:35 am
it will not slip in stock mode as the torque is what is making it slip so you will have to spend you money on a sachs clutch disc  :sad1: but then it will never slip again
Post by: subaru26675 on May 03, 2010, 10:35:09 am
you have pm  :happy2:
Post by: Poverty on May 03, 2010, 12:27:16 pm
does it only slip under WOT or normal driving also?
Post by: scotta on May 03, 2010, 01:49:33 pm
Yep only on full bore!
Ive refalshed it back to standard and taken it a run - no issues on standard even on full bore up hill.
Was thinking i might have a word with superchips and see if they have a map with abit less peak torque further up the rev range? Anyone know if this is possible?
Post by: Poverty on May 03, 2010, 02:02:56 pm
deffo possible, its either that or just shift down so you are above 4k rpm when giving it the beans
Post by: scotta on May 05, 2010, 12:41:34 pm
Got quoted £580 for an oem replacement clutch fitted including vat. :confused:
Post by: robern2 on May 05, 2010, 01:32:51 pm
I paid £780 for a Helix clutch fitted inc new release bearing.
The Helix is comparible to the Sachs item discussed on this thread.
Post by: scotta on May 05, 2010, 01:53:26 pm
Spoke to superchips who have just sent me a different map to try with a less aggressive torque delivery. Will give it a bash later on tonight and see how it goes.
Post by: Saint Steve on May 05, 2010, 02:45:27 pm
You may not like it. I didnt :sad1:
Went back to the Full fat version :smiley:
It will only get worse over time if your running any sort of map. So as Matt said, start saving up for the Sachs.
Post by: scotta on May 05, 2010, 03:48:11 pm
Hmmm will see how it goes! Did you have to flash it back to standard first before installing the Diet version?
Post by: joesgti on May 05, 2010, 03:58:51 pm
has anybody had any experience or hurd of a clutch slipping on a KO3??
Post by: chungster on May 05, 2010, 04:34:34 pm
yup. All depends on which brand of OEM clutch you have. If you have a LUK one then start saving for a replacement.
Post by: wigit on May 05, 2010, 04:35:13 pm
 :surprised:
Post by: joesgti on May 05, 2010, 04:40:12 pm
how do i know?? my cars an 05?
whats the symptoms
Post by: chungster on May 05, 2010, 04:53:10 pm
Early cars were known to have the crappy LUK clutches. My 06 one did and failed as soon as remap went on
Post by: joesgti on May 05, 2010, 06:40:03 pm
now your starting to worry me!!
Post by: gazbutS3 on May 05, 2010, 06:42:11 pm
don't worry Joe, we all know your car is a mutant, it should have blown up years ago but hasn't!!! :laugh: :laugh: :laugh:
Post by: Saint Steve on May 05, 2010, 07:20:56 pm
Yes, load your stock map, then Bluefin will email you the new one.
Post by: winrya on May 05, 2010, 08:37:04 pm
Most model year gti's had LUK clutches, it was the first batch of flywheels which were flaky and caused clutches to fail.  They had a short period of using sashs clutches but have now gone back to a modified LUK clutches.  My 05 gti failed at 39k :sad1:  LUK are the only clutches VW will put on the gti now
Post by: joesgti on May 05, 2010, 09:02:31 pm
 :grin: :grin: :grin:
i lol'd!!
Post by: MattPoss on May 05, 2010, 09:46:12 pm
My diesel had a LUK flywheel fitted from new but got recalled shortly after, the replacement was a Sachs one. After 51k and 2 flywheels, it's needing another one now. I'll have to 'adapt' my driving slightly to suit it I think, quite a lot of torque going through it at the minute!
Matt
Post by: mk2mexico on June 17, 2010, 09:07:59 am
Mine is a 06 gti 3 door manual
 after a stage 1 remap and while under 4k in the rev range and in say 4/5/6th gear when u floor it it judders and then takes off is this the dual mass flywheel going or clutch slip??? it also does it when cornering at a fair speed?
Post by: MAT ED30 on June 17, 2010, 09:13:21 am
if its a judder i would say dmf is on its way out so turn you map off to help save it the abuse until you can sort it
Post by: vRS Carl on June 17, 2010, 10:02:22 am
My Clutch went at around 17k miles on my vRS (K03) when i was REVO Stage 1 mapped.
I just got a Sachs Clutch fitted and it wasn't much more than a standard OEM one  :happy2:
Post by: mk2mexico on June 17, 2010, 10:14:17 am
Thanks for the info  :congrats:
the clutch is fine and not slipping i think?
it looks like the dmf cant cope withe the extra tourqe at low revs when i boot it
im off to re map the car back to standard
ah well it woz good while it lasted. :ashamed:
Post by: john_o on June 17, 2010, 01:38:29 pm
I wouldnt be too hasty on the clutch being the issue mk2mexico
You state it also happens when    'it also does it when cornering at a fair speed'  , cornering should have no bearing on whether the clutch is slipping or not.......
judder could be overboost , poor engine mounts , coilpack misfire any number of things.
have you scanned for fault codes from the ECU?
