All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Pullafacial on July 07, 2010, 09:05:21 am
Title: ESP & tyre pressure sensor warning light coming on?
Post by: Pullafacial on July 07, 2010, 09:05:21 am
3 or 4 times in the last couple of weeks my ESP and tyre pressure warning lights have decided to come on mid journey and stay on until ignition is switched off and on again.
Anyone seen this before or got any ideas as to what it could be?
Title: Re: ESP & tyre pressure sensor warning light coming on?
Post by: S2 Ant on July 07, 2010, 11:50:06 am
Have you checked the tyre pressures?
Post by: Pullafacial on July 07, 2010, 01:03:09 pm
Hi ant - not recently, could a low pressure on a tyre cause ESP light to come on?
When this happens, the buttons near the ashtray won't turn off the lights.
Post by: Chris on August 03, 2010, 09:15:56 pm
Dont the tyre pressure run off the ABS Sensors, thought they detect a difference in rolling radius. Maybe its an ABS sensor problem
Post by: mk2mexico on August 06, 2010, 04:20:31 pm
Tyre psi is linked to the abs set your psi to 32 and reset tpm
Post by: edd666999 on August 06, 2010, 04:54:45 pm
Just checking, you need to hold that button down for a while before it turns the warning off?
Post by: S2 Ant on August 06, 2010, 04:56:12 pm
Pressing and holding i believe resets the value that would trigger the alarm again
