All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: bacillus on February 08, 2009, 03:12:39 pm
Title: Comparison on Neuspeed Intake
Post by: bacillus on February 08, 2009, 03:12:39 pm
You may want to reconsider after viewing this pic
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fsys9five.com%3A8080%2Fetc%2Fneuspeedvsbshvsstock.jpg&hash=a3b0cc5d3f240c5959d149b7fe574b7c46a43e3d)
Sourced from this thread  http://www.golfmkv.com/forums/showthread.php?t=77246
Title: Intakes
Post by: SteveP on February 09, 2009, 08:55:46 pm
I have split this topic off from Matt a's for sale thread  :happy2:
Title: Re: Comparison on Neuspeed Intake
Post by: KRL on February 12, 2009, 02:05:46 pm
Anybody know if the BSH intake is available in the UK?
I think it looks really good.  It combines the the best of both worlds - CAI and HAI.
Post by: bacillus on February 13, 2009, 07:50:14 pm
Unfortunately you'll have to order direct from BSH.
The website doesn't yet give you an overseas shipping option so you'll have to email Phil or Brandon for an inclusive costing.
In case anyone is wondering what the graph actually indicates, this is what ross tech says:
"Your peak airflow should be roughly 0.80 times your horsepower if you are close to sea level. So, if you have a stock 150 hp 1.8T, expect around 120 g/s. If you see significantly less than that, you MAF may be on the way out. Also note that airflow will be markedly different at higher altitudes due to reduced ambient air pressure, especially with naturally aspirated engines that do not have forced induction to overcome that deficiency. This still works if you are chipped, but "race" programs may make more power through timing, rather than airflow. Therefore, take all readings with a grain of salt".
Post by: niallo on February 18, 2009, 06:18:50 pm
just enquired bout bsh intake and the guy from bsh quoted 352 dollars which is 248 pounds.
Post by: RedRobin on February 18, 2009, 06:57:01 pm
Not trying to put you off but don't forget about shipping costs and UK import feckin tax.
Post by: Top Cat on February 18, 2009, 06:59:01 pm
There may be a better offer coming soon on this intake. Just hang fire  :wink:
Post by: bacillus on February 18, 2009, 07:14:42 pm
Sounds intriguing.....
Post by: niallo on February 18, 2009, 09:26:04 pm
that includes shippin but not tax haha . damm government
Post by: KRL on February 18, 2009, 11:36:34 pm
I like the sound of that!
Post by: Howardvwgolf on February 23, 2009, 10:37:24 pm
me too, very interesting!!!
Post by: matt a on February 26, 2009, 08:10:14 am
Had a look at the BSH, the pipe work and filter seem very similar to the new speed. The filter may drop down fractionally lower, but the difference seems to be the filter enclosure/cold air feed, therefore the Neuspeed should produce a similar result with the addition of a similar housing.
Post by: RedRobin on February 26, 2009, 08:26:54 am
It seems to me that all the 'lollipop-on-a-stick' filters are pretty similar and that their extra performance claims depend on the filter enclosure and the car they are tested on. Consequently it's quite difficult deciding which aftermarket air intake is best to buy.
For now I'm happy with my ITG in the stock box with Carbonio, but I'm not kidding myself that there are many gains, rather that it (hopefully, and I'm told) improves efficiency and that it has not been an issue when I was under VW warranty. Oh, and that the Carbonio looks pretty  8)
Post by: matt a on February 26, 2009, 08:33:18 am
You're right Robin, does seem to be down to the enclosure, but worth mentioning. The Neuspeed certainly does lack one, and I pretty sure the figures would be different again, if it had one.
