All Things Mk5 => Mk5 General Area => Topic started by: jimmyca69 on October 22, 2010, 02:34:31 pm
Title: High Milers
Post by: jimmyca69 on October 22, 2010, 02:34:31 pm
Afternoon all
How well does the MK5 GTi cope with high miles?
One i am looking at has done 105,000 with a FVWSH - exact spec im after and under budget. But very wary of buying a high miler like this even though the garage selling it provide a 2 year unlimited warranty (usually not worth paper written on).
Title: Re: High Milers
Post by: edd666999 on October 22, 2010, 02:43:43 pm
loads of people running high miles.
As long as its been service correctly.
Post by: Neimad on October 22, 2010, 02:51:12 pm
My car is at 98k miles now and (touch wood) is motoring along fine -- it's actually due to go in for its sixth long-life service next week.  So far I've had no major problems other than the air-con compressor dying (a common MK5 Golf fault) and some uneven wear on the rear tyres.
That said, whilst it has weathered the miles well I can definitely feel it's "not as tight" as it was when I bought it four years ago.  I'll probably end up keeping it for another two or three years though and I'm hoping it'll keep on serving me as well as it has done to date.
Post by: jimmyca69 on October 22, 2010, 02:53:44 pm
Thanks for the replies  :smiley:
Especially interested in those who run high milers and what kind of niggles to look out for around the 100k mark  :happy2:
Post by: Garth on October 22, 2010, 03:06:16 pm
Mines done 81k now and things have been falling off it at an increasing rate since 55k  :sad1:
I've got a full VW service history and always look after my cars but this one doesn't seem too strong...
Post by: jimmyca69 on October 22, 2010, 03:13:30 pm
Hey Garth, what exactly have you had isues with?
Post by: RedRobin on October 22, 2010, 03:15:37 pm
My 05-plate 06-build GTI DSG is coming up to 90k miles and has felt even better since about 30k miles. Regularly serviced.
CmdrFire's has done over 100k and is going strong too.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDetailing%2FStickers%2FSellVolkswagen.jpg&hash=89f483507e384c1cca94402dfba40e5e53cf577e)
Post by: cmdrfire on October 22, 2010, 04:32:51 pm
105k miles here as Robin says.
Three main bits of after-warranty work: DSG selector switch replaced (expensive), fuel pressure sensor replaced (not too expensive), and corrosion on the radiator which required rad replacement the other week (expensive). But I'm not too fussed about the rad replacement as it's the original rad from my accident a few years ago.
Post by: dajonic on October 23, 2010, 01:17:27 am
115K miles and all still good. No rust, a few stone chips from the motorway commute and thats about it. Interiors still good especially the drivers seat and bolsters althoughthe steering wheels a bit shiny now in places. Stops and starts as well as it did when I bought it. :happy2:
Post by: RedRobin on October 23, 2010, 08:55:21 am
^^^^  It must be a Volkswagen!  :notworthy:
Post by: Nasir on October 23, 2010, 09:56:05 am
Leather cleaner will get rid of that shine
Post by: seiko on October 23, 2010, 07:23:43 pm
mine has done 93k full service history, 2005 model paid £6500 done full R.A.C hpi check no isues only had it 4 weeks, had to change the water flange and seal so far, it pulls wel, and drives wel, realy pleased with the car, wish i had bought a mk5 years ago
Post by: dajonic on October 23, 2010, 08:16:40 pm
leather cleaner   Cheers Nasir :happy2:
Post by: Jonboy72 on October 23, 2010, 08:30:57 pm
http://www.liquidleather.com/liquidl.htm
thats what i use.....
J
Post by: jmspear on October 23, 2010, 09:01:22 pm
108,000 miles and going very strong, upgraded the engine at 90k - ITG, HPFP, stage 2+ and TBE and it delivered 275 BHP and 315lbft on the rollers which says it all aboutthe fettle the engine is in, lots of motorway miles though, about 25k pa. This is key if it is 100k longer journeys on motorways, no issue, if 100k around town different kettle of fish.
Issues - air con pump failed, at about 60k, (common fault as already said) battery failed at 4.5 years, and had a wiring fault in the door (was fixed under warranty) otherwise has just been normal maintenance, has been serviced every 10k miles and always use long life oil, if well serviced pretty bullet proof very very well made car - If only everything in (this is my third mk V in the family and v v happy with choice and will be replaced by another VW when the time comes   :happy2:
Post by: Garth on October 24, 2010, 11:54:02 am
Suspension springs and top mounts have both broken, dv has split, evap solenoid valve has broken, there is still an unidentified fault on the engine that 2 VW dealers cannot solve.
The electirc folding mirrors fold in but not out, the rear wiper comes on when it feels like it (usually when the engine is started and the only way to stop the wiper is turn the engine off).
The electric motor in the seat for the lumbar has died.
That's all I can remember off the top of my head apart from the rattles and squeaks that keep appearing
Post by: Nasir on October 24, 2010, 12:51:47 pm
@Garth, the wiper fault is common. I think you need a new wiper motor as some of the earlier ones were known for this problem.
Post by: jimmyca69 on October 26, 2010, 11:25:29 am
Only problem i see is that a lot of the higher mileage cars are owned by same person so are looked after to your standard.
Buying a high mileage car though is slightly worrying me given i cant really know if its been looked after. I know FVWSH is a must now, and ill also do the usual checks for the mentioned problems.
What are the major service schedules to look out for and ideally have receipts for these?
Post by: Garth on October 26, 2010, 03:24:49 pm
It must have had the cambelt changed and ideally the waterpump too. I have recently had mine done and it's a big bill you don't want just after buying a car
Post by: dajonic on October 26, 2010, 03:30:29 pm
Did I say 115k and no probs...D'oh!! New turbo needed :sad1: Having said that I'm the third owner and this is the first major thing going through the service records that has needed replacing.
Post by: RedRobin on October 26, 2010, 04:39:52 pm
....Sorry to hear that, mate. Been there and done that.. You K03 or K04? maverick has a K03 for sale.. Check the For Sale section.
Post by: dajonic on October 26, 2010, 04:48:28 pm
Yep K03. Bought one from BDM with 500 miles on it.
Post by: RedRobin on October 26, 2010, 05:13:00 pm
....Can't do much better than only 500 miles on it!  :happy2:
Post by: Teutonic_Tamer on October 27, 2010, 04:12:00 pm
What are the symptoms of your engine fault?
There was a TSB on that.  Usually needs a new door controller.  Should have been done under warranty.
As above, a TSB was issued.  Can't remember what the cure was though.
Carefully check the wiring and connections under the seat - the wires actually tie-wraped to the seat frame, and those which go under the carpet under the flap.  But make sure your ignition is OFF if you want to unplug any connectors.
Oil SWMBOs ear-rings.  :wink:
Well that's what they did in the advert!  :evilgrin:
Post by: djhorace on October 28, 2010, 01:29:15 pm
I personally wouldn't. I know of 2 BWJ (K04) failures, one fairly catastrophic (Piston Ring/Scored block), and at least 3 BWA engines that have had issues, moreso with higher miles.
Post by: Teutonic_Tamer on October 28, 2010, 08:21:49 pm
With the greatest of respect mate, I'd strongly suggest those engines in question have been abused.  The scored piston rings and block is an absolute classic case of thrashing the ar$e off the thing from stone cold - and no doubt not using the correct oil.
And just in case you arn't aware, the 2.0 TFSI is basically the same block and bottom end as the 1.8 20vT - versions of which run reliably with sommat like 500bhp in the international Formula 2 championship.  Virtually all modern VAG engines are fairly bullet-proof, just not idiot-proof.
Post by: Garth on October 29, 2010, 04:46:53 pm
Engine block, yes.... electrics and ancillaries, no.
Small parts such as dv's and coil packs have had a poor reliabilty record for a number of years. As with all moderm engines, they have too much in the way of electronics which can (and do) go wrong. That said, VW is far from the worst culprit!
On a positive note, my engine fault has been identified and fixed by a local mechanic.... for free. Turns out it was only a loose connection on the lambda sensor. Can you believe 2 main dealers took a day to investigate and couldn't find a fault? It took my local guy 10 mins to fix it  :congrats:
Post by: Teutonic_Tamer on October 29, 2010, 06:57:14 pm
Ancillaries are debatable as to weather they are part of the actual engine.  Just like the dodgy batch of air conditioning compressors - just because one of those might fail, you wouldn't describe the engine as a whole as being weak or unreliable.
Hmmmm . . . with a DV, I'd probably class that as a consumable, similar to say spark plugs, air filter, fuel filter - so it is unfair to include DVs in overall reliability, especially as they only seem to go south after a remap.
And coil packs - don't agree.  The modern single coils (push-in type, without any screw holes) introduced around 2000, have been increadibly reliable.  It was the earlier screw-in type coils on the 1.8 20vT which had the reliablity issues - and these were eventually solved when VAG used a new supplier.
Again, 'electronics' are not the same as the lumps of metal which make up the physical engine.  And Bosch ECUs are bullet-proof.  And if you try to include things like coolant temp senders, or camshaft position sensors - again, not part of the main engine, and are no more unreliable than the same components on a Vauxhall or BMW or Reno.
Exactly.  I would say petrol Renault engines are considerably less reliable than any VAG motor - an achilies heel on Renos is the throttle butterfly gumming up - 1980s Vauxhalls used to do that!
That's a great result - but that would have shown up during data logging - something the VW stealers seem utterly incompetent to do, even though they have the VAS5052 tablet.
