All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: 182_blue on February 22, 2009, 02:42:06 pm
Title: V4 maps for RNS 510
Post by: 182_blue on February 22, 2009, 02:42:06 pm
Anyone got it ?, could do with this myself, wonder what updates are on it
http://cgi.ebay.de/VW-Navigations-DVD-Westeuropa-V4-RNS-510-RNS510_W0QQitemZ260364850286QQcmdZViewItemQQptZTechnik_Auto_Hi_Fi_Navigation_Einbau_Navigationssysteme?hash=item260364850286&_trksid=p3286.c0.m14&_trkparms=72%3A1229|66%3A2|65%3A12|39%3A1|240%3A1318
Title: Re: V4 maps for RNS 510
Post by: SteveP on February 22, 2009, 07:14:27 pm
At that price I would think it's cheaper to buy it directly from the stealers over here  :confused:
I will give mine a call in the morning to see if they have had any cars in recently with the V4 disc  :happy2:
The latest Audi maps on there MMI system are much better than the VW's v3 one's, so I hope the v4 will bring some improvements.
Post by: 182_blue on February 22, 2009, 08:27:45 pm
i would be interested to see what's different, also i wonder if we can keep the speed cameras on ?
Post by: JPC on February 23, 2009, 12:08:39 am
i reckon v4 will give us full post code search! fingers crossed
Post by: xxx_mojo_xxx on February 23, 2009, 12:34:25 am
Let's hope they update the maps as well... some of the road details are woefully out-of-date where new bypasses, round abouts, etc. have been built.
Post by: golfman on February 23, 2009, 06:49:19 am
And there's also a new Firmware 1100 for the RNS 510 Rev. A
With this firmware the RNS 510A gets the same features as the RNS 510B like bluetooth audio support or AV-Out!
My m8 @ vw has this disc so will be getting my firmware updated 8)
Post by: xxx_mojo_xxx on February 23, 2009, 09:37:50 am
Do you normally have to pay for the firmware upgrade and nav disc update?
Seems a bit unfair if you already have an older version, and its a simple task of bunging in a disc to bring things up-to-date?
Post by: SteveP on February 23, 2009, 09:41:55 am
^^^ Yes each new disc is chargeable.
Previously the new versions for the older MFD2 DVD Navi where around £165 each.
Post by: JPC on February 23, 2009, 09:48:29 am
ouch...luckily ive got a brand new V2/B unit with the latest firmware. and ill be hoping to find the V4 maps on the "internet" somewhere! ;)
Post by: xxx_mojo_xxx on February 23, 2009, 09:57:17 am
How do I check the firmware version?
JPC - please give a shout if you find the maps online.
Post by: cmdrfire on February 23, 2009, 11:32:57 am
The V3 maps are online already and are quite good, with TMC enabled etc. I've got a "B" version RNS-510 - there don't seem to have been any updates for that as yet.
Post by: 182_blue on February 23, 2009, 11:49:15 am
get in the car, don't put key in ignition, manually turn the unit on via the unit and immediatly press and and hold set up button for about 15 secs, this should get you into the hidden menu and here you will find map version an software etc etc, this works on my revision unit
Post by: xxx_mojo_xxx on February 23, 2009, 12:00:07 pm
Tried it... I just get a setup menu showing AM/FM/DAB....  perhaps I'm doing something wrong.
Post by: 182_blue on February 23, 2009, 12:37:30 pm
How new Is your unit ?
Post by: cmdrfire on February 23, 2009, 12:49:45 pm
Newer A firmware (and all version B) don't allow you to do this. The setting needs to be enabled in VCDS.
Post by: xxx_mojo_xxx on February 23, 2009, 01:55:38 pm
My RNS 510unit has the new touch screen.  It also came with the V3 disc.  Car is only 3 months old.
Post by: 182_blue on February 23, 2009, 01:59:08 pm
yeh, which is why i asked how new it was, out of interest what do you adjust in VCDS now then ?
Post by: 182_blue on February 23, 2009, 01:59:55 pm
Looks like you will need VCDS then
Post by: xxx_mojo_xxx on February 23, 2009, 03:08:27 pm
Is VCDS the VAG-COM dongle thingy?
Post by: JPC on February 23, 2009, 03:34:27 pm
yep. thats right.
Post by: 182_blue on February 23, 2009, 05:16:25 pm
think i will stick to version 1020  :signLOL:
Post by: vRStu on February 23, 2009, 05:18:35 pm
There is an adaptation channel to modifiy with VCDS to enable the menus.
Post by: 182_blue on February 23, 2009, 05:30:12 pm
ahh, so if i update to latest version i can still get the menu when i have VCDS it , what doe the update do ?, anything usefull
Post by: golfman on February 23, 2009, 09:56:42 pm
Hi guys i have just updated to the latest software 1100 and im afraid to say it wipes ure map and hdd,so i will have to reinstall map and all my saved music again :sad:
Post by: xxx_mojo_xxx on February 24, 2009, 09:54:55 am
oh dear...sorry to hear that!
So what are the changes/improvements?
Post by: 182_blue on February 24, 2009, 06:07:59 pm
where did you get the software
Post by: golfman on February 24, 2009, 08:47:40 pm
All the vw dealers have the latest software disc,my m8 from vw upgraded mine :grin:
Post by: xxx_mojo_xxx on February 24, 2009, 09:14:08 pm
How about ripping the DVD and posting it somewhere for everyone to enjoy  :evilgrin:
Post by: JPC on February 24, 2009, 09:36:52 pm
ditto! ;)
Post by: 182_blue on February 25, 2009, 06:34:12 pm
x 3
Post by: 182_blue on February 25, 2009, 08:29:22 pm
anything changed ?
Post by: 182_blue on February 28, 2009, 08:20:26 pm
i got the new firmware but dare not install it lol
Post by: SteveP on February 28, 2009, 08:22:50 pm
^^^ Go on do it, it will be fine  :evilgrin:
Then I know if it's ok  :rolleye:
Post by: 182_blue on February 28, 2009, 08:26:18 pm
well, i was going to then i saw Tommy cupra had said some units had been bricked ? :confused:
Post by: 182_blue on March 01, 2009, 05:46:14 pm
tried the update i downloaded but got this error ?
' a swl disk is detected but it is unvalid because of clamp state. please switch clamp state to hour mode and re insert disk''
Post by: 182_blue on March 01, 2009, 07:38:59 pm
ignore last, i sorted it (just needed coming off 24 hours on clock)
oh and GULP
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fvv19%2F182_blue2%2FIMG_0325.jpg&hash=9d1b7c9c29aa3748846953c35749209eb238ace4)
Post by: JPC on March 01, 2009, 09:21:09 pm
is your version A or B shaun?
Post by: 182_blue on March 01, 2009, 10:16:30 pm
it's a B now  :signLOL:
Post by: cmdrfire on March 02, 2009, 12:36:30 am
Did you upgrade the motherboard? That is the only way to make a Version A into a Version B, there is some hardware difference apparently.
Post by: 182_blue on March 02, 2009, 08:25:50 am
Have you personal experience of this ?, some people say you need too, some say not, its now telling me its a B version though, doesnt bother me either way TBH
Post by: 182_blue on March 03, 2009, 01:28:49 pm
Woohhhoooo, Map version 4 loaded , lets hope it has some changes, just need do add speed cameras again  :happy2:
Post by: xxx_mojo_xxx on March 03, 2009, 05:12:17 pm
So, where is the V4 DVD?  I'd like to update my system as well, plz.........  :party:
Post by: 182_blue on March 03, 2009, 06:09:00 pm
VW dealer ? :happy2:
Post by: xxx_mojo_xxx on March 03, 2009, 10:31:08 pm
Thanks... that one came to an abrupt end.  Ok, so what arethe changes/improvements - before I go and fork out for one...?
Post by: 182_blue on March 04, 2009, 06:46:43 am
Not alot from what i can see, postcode is still the same too, im guessing there's some road changes there but not in my area
Post by: 182_blue on March 04, 2009, 09:50:02 am
if anyone wants the 1100 firmware update its here http://www.filefactory.com/file/af25he8/n/rns510fw1100_rar
please do consider the implications of upgrading, and do so at your own risk
Post by: JPC on March 04, 2009, 10:58:21 am
oh gutted to hear the post code is the same! is there anyway to create an audible warning for POIs btw? speed cameras etc?
Post by: 182_blue on March 04, 2009, 11:00:46 am
there is no way at the moment that i hvae seen, im sure it could be done with custom software but nobody will go to that trouble TBH
Post by: xxx_mojo_xxx on March 04, 2009, 03:35:10 pm
182_blue - looks like your the resident expert here...  :happy2:
How do I check the current firmware version on my RNS 510 unit?  And, what changes are there with this newer 1100 version?
Post by: 182_blue on March 04, 2009, 04:51:15 pm
well, depending what version your running you can check by opening the car, getting in, don't put key in ignition, start up the nav unit using the knob on the unit, then when VW splash screen starts up press and hold the set up button for about 15 secs, then you enter a hidden menu, here you will find your map version and HW number.
 certain versions wont allow this until programmed to be allowed to do so via Vag com (bear in mind updating to 1100 will necessitate the use of vag com (one time only though) to enter this hidden menu)
As i said doing this update could Brick your unit, so do so at your own risk
heres mine now
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fvv19%2F182_blue2%2FIMG_0330.jpg&hash=144bec32e2edc57489a0d42758b5279b52f7906e)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fvv19%2F182_blue2%2FIMG_0333.jpg&hash=98c414d775f3e2ac36fb9a0a78df9edde24f5f24)
Post by: xxx_mojo_xxx on March 19, 2009, 01:54:34 pm
heres mine now
Ordered the V4 from VW.  Will this have the firmware update on it as well?
Apologies in advance...but how do I check my version number - and I don't have this VAG-COM thingy (what ever that is)?
Post by: 182_blue on March 19, 2009, 02:13:31 pm
i dont think the firmware comes with the map (im told not anyway), your dealer can do it for you though, as for firmware check the text you just quoted LOL
copied here for you
heres mine now
Post by: 182_blue on March 19, 2009, 02:13:59 pm
ps, you know how much the disc is dont you !!!!
Post by: xxx_mojo_xxx on March 19, 2009, 02:18:50 pm
Just over 200 bucks... it's on order.  So, if I get this right I have to ask VW to do the firmware update separately?
Post by: 182_blue on March 19, 2009, 02:23:45 pm
yeh, if they will do it for you then fine, not sure if its chargable ?, just say you find it slow when you touch it and your mate has had an upgrade which solves this
ps, you dont need the upgrade for v4 map, it just makes the unit a bit more responsive
