All Things Mk5 => How to Guides / Troubleshooting => Topic started by: PaulGTI on June 03, 2011, 10:45:18 am
Title: VCDS Fault Codes for Sat Nav MFD2
Post by: PaulGTI on June 03, 2011, 10:45:18 am
Hello
A friend of mine recently bought a MK5 Gti so I did a scan on it with Vag Com and come up with the errors below. All seem related to the MFD2 that has been retrofitted. It all seems to be working fine, Sat Nav works as does the instruction display on the highline dash and compass.
So does anyone know what to check for ? Could the last owner have just installed the stereo and not done any coding ? Or does it need a newer CAN gateway ? or....?
Thanks for any help
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76
Mileage: 53100km/32994miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH15---    Serial number: VWZ7Z0F8184473
   Coding: 040300031C070060
   Shop #: WSC 00366 210 91421
   VCID: 2D5BFA22CD81
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
   Component: GSG DSG         070 1305
   Revision: 04507000    Serial number: 00000610090885
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 2241191E845F
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   VCID: 73EF2C5A6B25
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 70E523561A33
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000006295125
   Coding: E58F8F2700041500001400001400000000087F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B5FF43AF395
   Part No: 1K2 955 119 E
   Component: Wischer 171006 020  0501
   Coding: 00038805
   Shop #: WSC 00000
   Part No: 1K0 955 559 AB
   Component: RLS     311006 020  0105
   Coding: 00208933
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 3N AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0UFKYJ
   Coding: 0013134
   Shop #: WSC 01269 785 00200
   VCID: 3D7BCA621DE1
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0012102
   VCID: 8103F692A199
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 973     HW: 1K6 920 973
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F8184473
   Coding: 0005403
   Shop #: WSC 00152 210 999999
   VCID: F0E5A3569A33
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 01080602000669
   Coding: 3F0F074007000001
   VCID: 2F67E02AC78D
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 254
                    Mileage: 47192 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:13:00
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
   VCID: F0E5A3569A33
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 B
   Component:      Navigation     0001
   Coding: 0000101
   VCID: 3875DB7632C3
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
            011 - Open Circuit - Intermittent
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         005 0968
   Coding: 0000564
   VCID: 3973DE7209C9
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 356BD24225D1
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0203
   Revision: 00020000    Serial number: 00000000000000
   Coding: 819002085103087F2D0484057008DAC690B800
   VCID: 830FFC9ABB85
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Component: Innenraumueberw.001 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000820
   VCID: 3A71C17E0CCF
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095
   Component:        Radio        0001
   Coding: 0010400
   VCID: E2C1D91E44DF
1 Fault Found:
            000 -  -
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D5BFA22CD81
End   ---------------------------------------------------------------------
Title: Re: VCDS Fault Codes for Sat Nav MFD2
Post by: vRStu on June 03, 2011, 10:55:02 am
Tick 37 in the CAN Gateway, that will sort that one out.
The MFD2 error depends on the equipment in the car - CD Changer etc.
Post by: PaulGTI on June 03, 2011, 11:22:52 am
Thanks mate will get that one ticked
Its got an ipod connector on it, no CD changer. ?
Any ideas for the Navigation Antenna error ?
Post by: vRStu on June 03, 2011, 11:47:31 am
If the nav is working I don't know why you'd have the GPS error, did you try to clear it off?
Post by: vRStu on June 03, 2011, 11:49:48 am
Is it a CD or DVD MFD2?
Coding is as follows -
http://wiki.ross-tech.com/wiki/index.php/VW_Radio_System_(RNS-MFD2_CD)
http://wiki.ross-tech.com/wiki/index.php/VW_Radio_System_(RNS-MFD2_DVD)
Post by: PaulGTI on June 03, 2011, 11:51:44 am
Yeh tried to clear them off but they instantly come back on.
Will give the tick in 37 a go and take it from there to see if it may clear up the GPS error too.
Thanks for your help mate, will report back over the weekend
Post by: PaulGTI on June 03, 2011, 11:52:40 am
DVD Version, will have a look through the Ross Tech guide
Post by: PaulGTI on June 03, 2011, 01:05:07 pm
Those links dont seem to work for some reason, i'll try having a search on there
Post by: vRStu on June 03, 2011, 01:19:06 pm
Hmm, working fine for me.
Post by: PaulGTI on June 03, 2011, 01:33:26 pm
Its the end bracket at the end not included in the link when you click on it, will work if copied and pasted though
