All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: ali6n2 on June 23, 2011, 09:55:58 pm
just got the car a few weeks back and planning to change springs and shocks, till now ive done pretty much most mods myself except paint work. Has any one had experience fitting them in, if so how difficult would it be for a newbie,
just that i dont want to start it and think crap.
cheers, also any suggestions on springs on shocks, budget of around 300-400
Hello!
I looked in to doing the suspension work on my car myself too. Unfortunately on the MK5 golf its not simple.
The rear suspension is simple enough but the front can be a nightmare.
To remove the front shocks you have to remove the front hubs as the shock sits inside the hub. this can be a problem as it means removing the drive shafts from the hubs.
Here is a link to a guide on an american forum:
http://forums.vwvortex.com/showthread.php?2213232
Hope this helps :happy2:
thanks mate, really apprecite that, looking into it now. what suspension have you gone for, u got any idea about the fk high tech spring and shock kit? No point me going for coilovers because im not going to slam it, around 50m should be enough
No need to remove driveshafts of hubs, just need to know how its done.
I will take some photos and post up next time we fit some. We take 3 hours for springs/shocks and springs (£120).
Where is your South location Dave, I'm looking for someone to fit my newly acquired AP collies and your Tyne and Wear place is a little too far for me. Would the South location be the same price?
wheres the tyne and wear one? that might b ok for me
Just done all mine took an 1 hour 45 min all in. Did have a ramp to use as it makes life so much easier
Does that mean you are selling up, upgrading or just bored? :laugh:
Have fitting facilities in Kent and Houslow.
NE35 9LN :happy2:
literally just come in after fitting new top mounts on the front of mine. they arent too bad to do but sometimes the part on the hub were the strut is needs a wedge in the back to split it ever so slightly and then knock the strut down. Did take me a while but that was due to dropping the subframe to get my anti roll bar off for new bushes.
