All Things Mk5 => Mk5 General Area => Topic started by: chris s on June 29, 2011, 04:43:54 pm
Title: Trouble Starting and Dodgy idle
Post by: chris s on June 29, 2011, 04:43:54 pm
Hi guys and girls... just wondering if anyone had any thoughts on what the issue might be with my car... when I start the car from cold i.e. first thing in the morning, it doesn't always want to start smoothly first time and the idle is not the most settled.... I’ve read about the PCV and coil packs (plugs are new), but wondered what people thought... a recent data logging session gave no faults at all so presume that rules out the coil packs... but wondered what the more knowledgeable people on here thought?
Title: Re: Trouble Starting and Dodgy idle
Post by: h4rdy on June 29, 2011, 05:08:04 pm
Yep mine started off like that and it was PCV.
Post by: chris s on June 29, 2011, 05:09:45 pm
I'm thinking that for £30 it might be as well to change it... I'll run the test first though
Post by: E30Dom on June 29, 2011, 05:15:50 pm
PCV? Is there a how to guide... mine sometimes coughs into life... though obvious runs fine :)
Post by: chris s on June 29, 2011, 05:26:33 pm
There is one on here somewhere... it basically involved taking the engine cover off and then detaching the pipe that connects to the PCV.. then with the engine idling block off the open end with your thumb, and if the idle improves the PCV is duff
Post by: h4rdy on June 29, 2011, 05:32:21 pm
Yep thats pretty much it but I don't like the thumb method as it is quite a powerful vacuum!
BSH PCV deletion, or a catch can.
Post by: TagnuT on June 29, 2011, 10:55:13 pm
How does it idle when warm?
Post by: chris s on June 30, 2011, 09:12:48 am
It's idle is Ok when warm... the only small thing I have notcied is that when pulling up to a standstill the revs appear to drop below the idling rpm before picking up again and then keeping steady.
FYI - it's an MY08 Ed30 DSG
