All Things Mk5 => Mk5 General Area => Topic started by: jordychris on October 29, 2011, 04:13:15 pm
Title: Vredestein Sessanta pressure
Post by: jordychris on October 29, 2011, 04:13:15 pm
I have just had 2 vreds fitted to the front on 18" monzas what pressure does everyone find best to run them at
Title: Re: Vredestein Sessanta pressure
Post by: rich83 on October 29, 2011, 04:15:28 pm
Should be about 33-34PSI.
Post by: stealthwolf on October 29, 2011, 05:35:14 pm
I thought Vreds were supposed to be higher pressure eg 41psi?
Post by: jordychris on October 29, 2011, 05:46:50 pm
That is why i am confused
Post by: winrya on October 29, 2011, 06:02:04 pm
No, I remember someone contacted vreds asking this question and their response was to run them as per vw spec.
I run mine around 2.3-2.4 bar. Vw recommend 2.2 but I've always found tyres wear far better at the marginally higher pressure.
Post by: Gene Hunt on October 29, 2011, 06:03:04 pm
..............on there ''official'' web site they do recomend high pressure?. I stick with the VW recomended pressure & they have handled/worn perfect. :happy2:
Post by: stealthwolf on October 29, 2011, 06:33:04 pm
If it's at what VW recommend, surely its 2.6bar or 37psi?
Post by: andrewparker on October 29, 2011, 07:01:20 pm
I run them higher, around 41PSI. Find they can be understeery otherwise.
Post by: rich83 on October 29, 2011, 07:27:07 pm
41PSI sounds a lot. More likely to get understeer with more pressure in the front tyres.
Post by: Saint Steve on October 29, 2011, 07:33:45 pm
i was told by a Vredestein dealer to run 40 PSI and have done on both sets i have used up, and have experianced balanced tyre wear on all tyres with no handling issues.
Post by: rich83 on October 29, 2011, 08:04:03 pm
How do they hold up under light to moderate braking Steve??? :popcornsoda:
Post by: andrewparker on October 29, 2011, 08:18:09 pm
It's more of a vagueness on turn it. The grip very well so putting more air in them tends to give crisper turn in feel.
I'm on my third set now and I'm not sure they're a tyre I'll buy again. The PS3s I tried were definitely worth the additional cost.
