All Things Mk5 => Mk5 General Area => Topic started by: garrardrj on February 09, 2012, 10:01:36 am
Recently acquired some of these. They have some sponge padding on the metal parts that attach to the car. The sponge has deteriorated and needs replacing. Did they come with this spongy part from new as i have never seen a new set ? What have others done or does anyone have a relatively new set they could put a photo on here so i can match the original as much as possible .
I've not seen a genuine VW set from new, but I'd highly recommend Helicopter Tape to protect your roof from the bars. I use Thule bars but never without taping up the contact areas on the roof :happy2:
My set have more of a rubber sheath that fits over the contact area. I'd either speak to VW, who I'd bet will be totally useless, or use tape as Lou says. With it being the bit that goes under the door still you will at least be unable to see it.
Yup, for the lip inside the door shut, I use duct tape & push a hole through it for the roof bar retaining lug to locate through. Helicopter tape for the outside only cos it ain't cheap.
You can also use frame protection tape from your local bicycle shop.
So have any of you got a photo of your roofbars bit that attaches to the car then ? I can then tape up as you state to protect the bodywork the same as you seem to have done. I'm just not sure the spongy bits came as standard and have been added by a previous owner......only pics of the genuine vw ones though :happy2:
Type "VW genuine roof bars" into Google Images :happy2:
Lots of pics, I don't see foam anywhere....
