All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: kinder1 on May 10, 2012, 09:14:56 pm
Hi all
I've recently swapped my RCD300 for an RCD510.I have yet to sort out the DAB aerial.Question- Has anybody used an window antenna,if so which would peple recommend?
I have looked at Celsus DAB Active Antenna,JVC HAL1 DAB Aerial,Kenwood DAB-A1 DAB Glass Antenna and other.All help would be appreciated
Hi all
I use window dab antenna, bought it for around £20 from ebay. Any DAB antenna with SMB connection should fit OK. Mine works fine.
Also use a window mounted aerial and works ok
Thanks guys
